I have this little old Grasshopper sitting around and it is time for it to go to the next generation.
Here is the breakdown of the Grasshopper to work with Hornet rear shock upgrade Tamiya 540 motor with 18T pinion gear CRP HD Steering links CRP Bearing kit CRP Front shock kit 2 sets of Grasshopper wheels Pair of stock tires for Hornet (rear) Pair of Proline Waffle tires (front) well used Set of Proline nobbie tires (front and rear) Pair of Sand Blaster Tires and brat wheels (rear) well used Front suspension arms for the Grasshopper 2 (on their way) Well that's the car part. Still sorting out what speed control to use but prob going to slap in a Tamiya ESC. Seems the safest for a youngster and less maintenance than a mechanical one. Going to the 3rd shock mod on the rear end using the grasshopper front spring setup and an LED light setup cause you know kids love lights, well so do I. Want to make up some custom decals for it too. By the way if anyone has some nice good resolution scans of the Grasshopper decals I would be grateful for them. I think a driver is in order too. I have seen some awesome painted ones here and I think I could go that route. I'll be posting up some pics as soon as I upload them to a photo sharing site. As of right now I have just torn down the little hopper and getting ready to give it a good cleaning. I did clean up the wheels a bit and sanded the rough edges of them so the look pretty nice so far. Going to paint them tomorrow during the day. Need to strip the paint off the body and fix some cracks. Nothing major. I will update as I go along to show the progress. Pics to follow. Shawn Current Project:
The Dylan Project Grasshopper
My Projects in the works: The Fighting Frog, The Restoration of my Fox, Back in the Day Blackfoot Racer, The JRX-2's, Yokomo YZ-10's of fury x3 I'm not a Re-re yet! |
Last edit: by hollowman.
I'm in the same boat with Grasshopper decals/scan. Haven't found any decent resolution scans yet & have been toying with the idea of buying a body+decal package, just can't afford it at the mo!
If I actually buy it, I'll try to remember to do you a decent scan of the decals, OR if you find something before then, could you send me one? Ta!
@Edou: Well yea I'm the fun Uncle! I wish my Uncle was into these things when I was a kid.
@eddrick: If I can't find some I will be fixing them up in Illustrator and they would be clean because they would be vector graphics vs what I would do in Photoshop. Current Project:
I can help you out with the scans. I have the Grasshopper in three colour schemes at a reasonable resolution.
Just pm me your e-mail adress (eddrick's I already have)...
The following user(s) Liked this: hollowman
Edou you are awesome! Just sent you a PM. Thanks again and I will try to find the manual for you.
Current Project:
Already mailed.
Eddrick, I thought I had your e-mail adress but it doesn't look like it after all. If you'd also like the scans to be sent, let me know what it is...
Thank you so much! These are great. Took a look at them and I can seriously do some good work with these. Going to put them through Illustrator next week to set up my custom set.
Thanks again Edou! Current Project:
On another note, I have some pics of the Grasshopper.
The Hopper as I pulled it from the box it was stashed in: You can see the Hornet rear shock upgrade.. The CRP Front Shock Upgrade: The Pro-Line Knobbies: Tamiya 540 Motor: CRP Parts: So this is what I have to work with. Currently just painted one set of wheels in a gloss black. Still figuring out the overall color scheme but the black wheels should look good. Going to get the chassis in some cleaner (dishsoap and hot water) and polish up the shocks. Pics to follow as I get the parts done. Current Project:
Last edit: by hollowman. Reason: fixed links
