my brother has a tamiya avante qd, it runs perfectly, but in needs a little tlc.
anyhoo, the rear tires were slicks from burnouts and whatnot. we needed new tires. my dad found a cheap rc car somewhere and i could take the rear wheels off, and the hexes were the same size as the avante ones but had heaps of plastic surrounding them, a few minuts with the drill helped fix that |
I've always wondered if QD rims are the same size as something else maybe 1/12 or 1/16 - could you have a measure & post your findings?
A cheap source of tyres might be foam pipe insulation tube, or foam bicycle handlebar grip tube, if you don't mind foam tyres. I've also seen small rubber tank tracks on Ebay, maybe these could be bonded to bald tyres? Nice bit of adaptation you've done there!
tire outer diameter 6cm
tire iner diameter 4.9cm (the bead which locks into the rim) rim width (rear) 3.1cm rim width (front) 3.2cm rim outer diameter 4.3cm rim inner diameter 3.8cm (estimated) hex size 6mm hope that helps also me and my brother, have been trying to get up a small dirt ledge, its really hard, the rocks have been chewing threw the spikes on the tires will post a vid soon |
Last edit: by zephyrin.
Sounds like the wheels are about Rough Rider size then? Tyres are smaller though
I think I prefer those green wheels to the originals! I take it you can't get matching fronts?
