Hi has anyone attempted to put after market wheels on there striker/sonic fighter. I just recently restored my sonic fighter but the wheels are no good.
Any suggestions/ideas where i can get good wheel/tires, thanks I am also after a lower chassis for a striker if anyone is selling one. |
Hey, you could always use the Wild One wheels and tyres which fit with no modifications required, and since there is a re-re of the Wild One you can pick a set up quite cheap
rear tyres front tyres rear rims front rims hope this helps, cheers Andy edit: have you got any pic's of your rebuild or the car as it sits now ? love to check it out If you can't fix it with a hammer, you've got an electrical problem mate
Last edit: by AndyAus.
Hi thanks for the tip about the wheels. I did purchase a 12 mm hex fitting wheels for the rear and used a hex adapter nut to put the fittings together, worked like a charm, however i had to saw of the hex nut as it was way to long. The wheels are just temporary until i get proper wheels for the sonic fighter. As you can see its not restored as yet, the bottom chassis was in a right state so i had to improv and figure a way to glue the front bottom chassis bit back together. Buying the front brace strengthened it more so now i dont have a problem. It would be cool if i can get a bottom chassis from some where if anyone is selling one cheap. Finally i got the crp parts from team crp, delivered today but had to pay custom charge DAMMIT!!!! I managed to replace the dog bones. The rest of the kit will hopefully be done of the weekend. I may go brush-less as i just won a brush-less esc 60amp on ebay. I may go even down to 12 turns, no more lower than that just to see how things go. For the rest of the car i will need to track down the right spray paint and buy official or repro decal sheets to finish it off. One more thing i will need to change the front hub to reinforced ones, hopefully they should be delivered sometime next week. |
Last edit: by sliderguy.
Hi,
Rims are the same of the grasshopper2, rookie rabbit and falcon. And a lot of other I think. For the color, it is the grasshopper2 same color. The Falcon and fighter rx are yellow and the rookie in pink |
