My custom Ford F150 Ranger 11 years 11 months ago #32074
Finally got some work done on my SRB Ford F150 Ranger with the Butterfly chassis that I made couple months ago. Still a long way to go to get it finish. May be till next spring.
Link to my Butterfly chassis:
tamiyabase.com/...nyone.html
Wide front axle and front body mount. I am unable to locate an original F150 front body post so I make use of the one from the Sand Scorcher.
Dual shock mount, roll bar and roll cage that I made. Spend some to figure out how to put the dent spot where the rear post is mounted on.
Link to my dual rear shock mount and roll bar:
tamiyabase.com/...d-xlt.html
Ford F150 Lexan body and some more goodies for the project.
Ball universal joint. Race Prep high torque motor. I can't even turn the motor shaft with my fingers.
The following user(s) Liked this: Jonny Retro, stingray-63, AndyAus
Last edit: by yellowcat.
My custom Ford F150 Ranger 11 years 11 months ago #32076
Most excellent :woohoo:
My custom Ford F150 Ranger 11 years 9 months ago #32951
Did some more work on the Ford over the holiday break.
Scraped the dual rear shock mount idea, changed it into a single shock mount instead. The mount is cut out of a 7075 aluminum sheet.
Fabricate a shock tower saver for the wide front axle.
Cut a piece of Kydex for the rear skid plate. Similar to the CRP one but extended to the rear cage.
Truck with new fabricate front body mount.
That's it for now! :)
My custom Ford F150 Ranger 11 years 9 months ago #32954
Very nice work. Love the little B&D Workmate - might need to get one of those.
What is the bent tube thing bottom left?
My custom Ford F150 Ranger 11 years 9 months ago #32957
The bend tube is for a rear hitch step that still in the works.
My custom Ford F150 Ranger 9 years 11 months ago #41635
yellowcat
I know this is really old, but do you know where I could find a set of those dual rear shock mounts for the scorcher?
Thanks
Bret
bret_kissick@msn.com
My custom Ford F150 Ranger 9 years 11 months ago #41645
yellowcat
Thanks
Bret
HI Bret,
You can make one yourself. Check out my thread:
