Sand Scorcher MK 1 Hot Rod 9 years 4 days ago #46448
  • frog66
  • frog66's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
The idea would be to make a Hot Rod starting from a front and rear end of a Sand Scorcher Mk 1.
then I took a re-release body to which I removed the superfluous parts
with a 5 mm plasticard sheet I made the bottom.
With 2 mm screws I secured aluminum strips to the bottom.
Then I covered them with 1 mm plasticard
That's what I set the front axle to the chassis
Sand Scorcher MK 1 Hot Rod 9 years 4 days ago #46449
Here is a beautifull project.
Sand Scorcher MK 1 Hot Rod 9 years 4 days ago #46450
  • frog66
  • Born to be Wild
  • Born to be Wild
I did the flameproof and I mounted the body on the chassis
I made a mudguard matrix printed with the vacuform machine
The following user(s) Liked this: oldwilly, VCR
Sand Scorcher MK 1 Hot Rod 9 years 4 days ago #46451
Hey man!
That looks amazing, great start, I will be following along :)
This reminds me of a couple of cars I saw at Bug Jams I went to back when I had a fairly serious VW addiction in the late 1990's, very cool indeed!!
My hat is off to you as well for having the " guts to cut " I just have never been able to do it to a body shell re-re or otherwise, unless I was grafting pieces together to fix one back to original. I just need to work on getting over my fear I guess, what with re-re bodies still available.
Keep up the great work!!
Sand Scorcher MK 1 Hot Rod 9 years 4 days ago #46455
  • frog66
  • Born to be Wild
  • Born to be Wild
Thanks stingray-63.
Oldwilly,you do not have to be afraid to cut the body, it's a simple job, just a cutter and a ruler.
Care must be taken to make cuts as accurate as possible.
Sand Scorcher MK 1 Hot Rod 9 years 4 days ago #46456
Oh!!! This is cool, count me in as a follower of this project :-)
Sand Scorcher MK 1 Hot Rod 9 years 3 days ago #46460
  • frog66
  • Born to be Wild
  • Born to be Wild
Thank you larbut.
Now steering system whit Acoms AS1 servo.
Sand Scorcher MK 1 Hot Rod 9 years 3 days ago #46464
Wow!!!! nice and clean. :y:
Sand Scorcher MK 1 Hot Rod 9 years 3 days ago #46468
Nice idea B) :)
Got to sya though, exposed servo horn as the lowest point of the car seems like asking for trouble :(
Sand Scorcher MK 1 Hot Rod 9 years 3 days ago #46471
  • frog66
  • Born to be Wild
  • Born to be Wild
there are no other solutions, in front of us goes the V8 engine.
The rod must pass below
Time to create page: 0.190 seconds
