Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #59880
The FF01 chassis is already assembled, I'm adjusting the height of the bubble, I already put Jaccs stickers on the wheels, the tire stickers I had them done, the windshield wiper is made in 3D printing that is not included in the kit, and the Tow Hook.
The following user(s) Liked this: stingray-63, Falcon3D
Last edit: by pandaracing.
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60072
like the towing eye :y:
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60080
Update !!! As the kit does not support led, I made these in 3D printing ...
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60203
Update !!! I'm doing the car's disc brakes, but I'm going to put only the discs, because I don't want to cut the supports that are inside the wheels, they are original and here in Brazil it is very difficult to find ...
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60206
Awesome
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60207
Thank you!!!
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60209
That's crazy of precision.
Assembly of my Tamiya FF01 Jaccs Civic 6 years 5 months ago #60215
Brakes ready and installed !!!
The following user(s) Liked this: Jonny Retro, stingray-63, Al
Assembly of my Tamiya FF01 Jaccs Civic 6 years 3 months ago #61315
  • mon
  • mon's Avatar
  • No Guts No Glory!
  • No Guts No Glory!
had a FF01 for a while and the biggest issue with it and the common problem is the screws connecting top and bottom to the chassis/motor section as there 10mm tappers, your better replacing three 15mm top and the two at bottom with 20mm as the no drilling is required as the holes are set that deep this also strengthens the plate fixings covering gearbox and i bet the holes cracking would never happen, makes you wonder if that was the plan on design at start, same goes for screws for top suspension back and front, as m3x30mm bolts straight though is a better option as you get damage were the screws fit i.e cracking but you need to drill straight though to sort that.
super champ, wild willy and ff01 clio willams
Last edit: by mon.
Assembly of my Tamiya FF01 Jaccs Civic 6 years 3 months ago #61316
This chassis will be in the ornament collection, I will not be used for racing.
But thanks for the tip !!!
Time to create page: 0.166 seconds
