Woohoooooo.go go go for the build Jonny
Step 6 complete ... holes in the bulkhead for the bumper mount (and the recesses behind them) should have been M4 but were M3, so I had to drill the holes out & use longer machine screws & washers & flange nuts behind.
Also note the rubber tube on the top of the front suspension - this corrects the silly positive camber to neutral, and lowers the front ride height. Steps 7, 8, 9 & 10 are all about fitting the MSC, servos & RX ... I don't have the aluminium "switch stay" so will have to come back to these later. Step 11 is fitting the RX switch & the rubber boot ... Step 12 has 2 sub-steps to build the front body post, resistor board & fir them to a bracket. 3D printed mechanism box didn't have space for the resistor wires or a hole for fitting the driver so I added those (and tidied up & touched in the paint): Step 12 is fitting the mech box lid & front bracket:
These are the irreplaceabl M3 x 60mm countersunk bolts (you can only get fully threaded screws now). Luckily the 2 needed for the rear suspension are ok, but the one for the upper gearbox is unuseable, thanks to the manual saying to use threadlock.
Step 13 - rear springs. Moving the collars down on the top lowers the back end & stiffens the rear suspension. |
These rear springs are funny. I like this chassis. Very interesting.
Step 14: motor & wheelie bar supports, brass pinion should be a wider, pressed on item:
Step 15: Gearbox, note completely ineffective "clutch" assembly, and the nylon idler gear that was in Grasshopper/Hornet/Lunchkin kits for years... 16, motor frame & roll/body mount hoop: Steps 17 & 18 - diff housing: 19, rear arms: 20, bearings & tie rods:
