Anyone had any luck fitting a Fox bodyshell to a or modern / readily available chassis?
Maybe not quite what you are looking for, but Tamiya has the Fox Mini on a GB-01 chassis from 2006.
tamiyabase.com/...6703-56703 Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Novafox is about 2cm smaller in width, so it should look a bit better.
Yes I'd think so, and it has the same wheelbase.
What other chassis would go well with the Holiday body?
