Oh man, I had a paint scheme worked out for you & everything ... |
ok slight technical hitch. the threaded hole on the chassis at the front where the triangle piece screws on with 3 3mm screws has stripped and the screw wont grip any more.
is there a cheap and effective repair to sort this out? maybe fill the hole with epoxy and redrill it or has anyone got any better methods to fix it? cheers |
Might sound a bit ghetto but I'd use a bigger screw |
I just drop some CA glue in the hole. (super glue) I find that works very well. And I find if you use the right screwdriver, it works the best. (Number 2 phillips)
My Projects:
No you misunderstood me, you put the super glue in the hole and let it dry. Then after about 10 min you put the screw back in. Because super glue etches into plastic, it make the hole a bit smaller (reduces the holes diameter) and stronger.
My Projects:
oh i get you now, sorry. good idea, i will try that out |
It really does work. I do it to all my Tamiya threaded parts. They all will strip at some stage...
My Projects:
The following user(s) Liked this: agemax
