Grasshopper resurrection 12 years 4 months ago #29405
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Okay, thanks. Most motors say 6-9.6V anyway but this one didn't get specified at all. Just wanted to check. :y:
I can understand a voltage that's too high would be more problematic.
Grasshopper resurrection 12 years 4 months ago #29413
:) I know too that a basic 380 can run under 12/14 Vdc. I have a 380 in my lghts washer pump on the C4 ;)
Grasshopper resurrection 12 years 4 months ago #29416
  • Edou
  • Hopping Mad
  • Hopping Mad
:evil:
Think you gotta have the right 380 for it though, otherwise some vaporisation may occur...
RS-380PH
RS-380SH
Under load, there will probably always be a minimum recommended voltage for the motor to not stall.
I reckon every spec will go down by 1/6 if you run a 6V pack.
Grasshopper resurrection 12 years 4 months ago #29441
:laugh: The 380 is undestructible. I dismantle the pump to relive it and I discovered a big rust packet not a motor. 3in 1 oïl and water in it and let's go it reruned. :blink:
Grasshopper resurrection 12 years 4 months ago #29517
  • Edou
  • Hopping Mad
  • Hopping Mad
:woohoo: :woohoo: :woohoo:
Almost ten years in the back of my mind and now a huge step closer to the ultimate Street Hopper...
Dyna Blaster rims in the house!
Grasshopper resurrection 12 years 4 months ago #29522
  • Edou
  • Hopping Mad
  • Hopping Mad
Grasshopper resurrection 12 years 4 months ago #29523
:p I had the same. Wich type of tires will you put on theme?
(TGX ones are pretty)
Grasshopper resurrection 12 years 4 months ago #29525
  • Edou
  • Hopping Mad
  • Hopping Mad
TGX tyres are great (radials especially) but may be harder to find than the Street Rover's.
Grasshopper resurrection 12 years 4 months ago #29533
:blink: are they not the same??? My first tgx has the dina blaster tires wich look like the street rover and the blitzer beetle metalic spécial
Grasshopper resurrection 12 years 4 months ago #29534
  • Edou
  • Hopping Mad
  • Hopping Mad
I think you may be right... they look similar (or exactly the same?) but have different part numbers. :huh:
Time to create page: 0.132 seconds
