Just some blisters on the shell though and a tiny bit of scuffing on the bumper.
Shows the setup is solid with the carbon knuckles, 3mm custom tie rods and servo saver. A normal Grasshopper would surely have suffered from a broken knuckle or bent tie rod. |
Very fast GH |
Cool video!
I like the cutting between "two" cameras, makes the video much more enjoyable to watch. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Looking good there, Flo.
Why no suspension (I see it)? Thanks Lars, thought it would make the vid a bit livelier. Movie Maker's pretty cool but these camera switches are a bit tricky to put together because you don't have control over too many frames (even though there's about 20-30 a second). I found that putting the particular clip temporarily to the slowest speed makes more of them available so it can be timed better. Some on board shots in between would also be great. Don't think high res cams cost much these days... And I saw a video earlier where someone used a head cam, then you can just look at the car and always get the right images! Some video editing enthusiasm there... |
Shocks have left their bath today and will go on a travel tomorrow.
Was planning to have sent them already but got caught up in the tyre stuff late in the afternoon (so I forgot). |
