I usually go with off white suit (with highlights/lowlights), flat red straps (with "Aluminum" details, semi gloss black & flat white for the helmet details, and usually only very the main helmet colour ... But in this case, I'm thinking very dark grey suit, flat medium blue straps, metallic grey for the main helmet colour - and use the helmet decals I always fit proper bearings in cars ... but then I always _intend_ to drive them ...
The following user(s) Liked this: Louisbaby
I usually put bearings in every car I build, but I don't intend on driving this one when it's done, if I don't install the bearings, I won't drive it...
Thanks for the info on the drivers, I suppose you don't have pictures do you? I struggle with the highlights/lowlights technique. My Projects:
Try this
So I managed to rip the chassis apart. This thing won't take long to rebuild, More dirty than anything else. I think this car ran no more than a hand full of times, Check the chassis - No scratches...
And to my surprise, the wheels have bearings in them... Gearbox look identical to the lunchbox. And finally, a box of parts... My Projects:
Cool car. It's got the parts to eliminate the weakest points on it's ancestors - wide front arms and CVAs all around.
They look like a good quality bearings btw. Edit - which is all quite irrelevant for a shelfer... |
I'd agree with pogo sticks on the original being a problem - along with the self-removing battery cover ... but worse is the ludicrous bump steer caused by the single front wishbones & the massive unsprung weight of the rolling rear axle - neither of which are improved Shame about the cracked tyres too |
I know, I'm quite bummed about that too. Is there anything I can do to stop it, or preserve what is left? I don't think I will find replacements in South Africa. But the advantage is it will be in a Display case soon. I'll post a thread on how to build cheap and easy display cases. My Projects:
Not sure there's much you could do about the cracked tyres.
Maybe one of the approaches in this topic is an idea : How to preserve rubber? Think it might help so it doesn't get worse at least. |
I've been looking for examples of driver colours, and found this guy:
Not completely sold on the colors yet, but it's a start. Started by smoothing off the injection marks, and roughing it up a bit. Got one layer of primer on it today, but now it's dark and the primer is drying. More time to search the internet for drivers... My Projects:
