Tamiya 58015 Rough Rider goes Baja 14 years 10 months ago #5449
Since a couple of weeks or so i was once again a little bit crazy idea in the head, the Rough Riders will be set to the Baja racer.
The rough concept, but still needs a little rightly be filed. Nothing here now in spite of the start.
Base is a tamiya Rough Riders Chassie from 1979. The Rough Riders was at that time and also the re-release already on deserts buggy, but it is not Baja racer.
The Chassie:
The rc box was away, so goes the remaining Chassie now in the conversion
The front axle was dismantled ...
... And dismantled. Then it went to the coarse before cleaning, the parts were then transferred to the ultrasonic bath.
Meanwhile, the plans in my head continuously, what relatively quickly clear was the longer spring travel must, as in the original condition. The original dampers offer very good Spring travel but for this conversion but a bit too little.
Here the dampers at the front axle the later their service (significantly more travel)
Here the dampers of the later rear axle
After the rough cleaning of the parts of the front axle was done I have the parts made to the smooth
Left smoothed, right orginal
TO BE CONTINUED...
Re: Tamiya 58015 Rough Rider goes Baja 14 years 10 months ago #5453
Sounds like another great build. I'll definitely be following this one! :cheer:
Re: Tamiya 58015 Rough Rider goes Baja 14 years 10 months ago #5486
Here some insperation :D www.tamiyaclub....058&id=108
Re: Tamiya 58015 Rough Rider goes Baja 14 years 10 months ago #5500
Thank You! the inspiration is good, but not doing enough against me.;)
Time to create page: 0.939 seconds
