Tamiya Falcon Rebuild 13 years 11 months ago #15957
Hi all
I have taken a punt on a cheap Falcon off Ebay i only payed
Last edit: by tamiya nut.
Re: Tamiya Falcon Rebuild 13 years 11 months ago #15959
Sorry I have the same problem on mine and look rear arms if they aren't brocken.
It is a fun car :y:
Re: Tamiya Falcon Rebuild 13 years 11 months ago #15971
They look like a real weak point in the design anyway i wonder if anyone has done a succesful modification to replace the plastic arms with maybe metal items i may look in to this
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16488
Been very busy on this the chassis is practically rebuilt now. I have decided to keep it as original as possible mainly down to cost more than anything as im on a very limited budget so i have just cleaned and rebuilt everything using the manual so it is bog standard including the old msc. I am in the process of manufacturing a metal front shock tower as i have removed the two weak and damaged plastic arms from the front bulkhead. I am planning on remounting the manufactured part by drilling the front bulkhead as it is very strong and gives plenty of opportunity for remounting luckily.
I am about to rebuild the rear shock and arm assembly but have come across a small crack in one of the rear arms where i think someone has overtightened the mounting screw. The crack is only on the outer edge of the mounting point not right through see pics. I was wondering if anyone had any ideas for dealing with it without sourcing the r parts tree for it? would plastic welding be effective as i have the front arms that i cut off that could be used to fill the gap if i melted them down? Any suggestions
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16489
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16490
This is what it looked like when i got it :sick:
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16495
:silly: Nice falcon!
It was not so :sick: . You made a very good restoration
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16498
Looking pretty good so far ... I can't really help you with your crack problem though :whistle: ;)
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16505
:unsure:
Maybe with glue like "ARALDIT"
Re: Tamiya Falcon Rebuild 13 years 10 months ago #16509
Time to create page: 0.185 seconds
