I was lucky enough to get hold of a half finished vintage 58003 Tyrrell some time ago.
As you can see from the pictures below, the "kit" arrived as a time machine. Just like someone had started building, lost interest, and put it all away in the attic. Here is what I started with: The chassis was half built, but nothing else done. Many of the parts were taken or fallen off the sprues. I disassembled everything, gave everything a good clean, and I'm ready for assembly. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Nice score
Yep, like that!
It always strikes me as odd that these old 1/12s are nowhere near as popular/collectible as the less rare (Or nice) 1/10 plastic cars
Me too, but I don't mind as I like the oldest 1/12s more Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Same here, they seem to be better thought out than the later stuff, plus there's the historical aspect (A big company's first RC models).
Can't complain though, if they're not popular it means the collectors will be so busy fighting over Monster Beetles & SRBs that the prices of the nicer cars remains relatively low!
Slow progress, I know, but I have lots of time
I always try to complete a model with proper period correct radio gear. This time is no different, but I don't have a NIP vintage Radio set to match the New built model. So, I removed the radio gear from my other P34 ,and restored the radio gear as best I could. The main problem is the servos and receiver which at some time had been glued to something. Before: I started off with a regular fine file, and went from there to sand paper in various grades all the way to Autosol and finally plastic polishing compound: They did not turn out as well as I had hoped, probably because I did not take enough time on each step. Anyway, I'm ok with the result and move on to mounting them. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
