Manta Ray shock springs 12 years 8 months ago #27699
Hello guys
I have restored my old Manta Ray and it has come out really good:-)
The thing is that the shocks springs are really soft and i just want to get some one that are harder. I could got with some aluminium hop up but i want to keep as original as possible.
My question is which springs do i need, i have looked at asiatees.com and rcmart and there are alot of them avaible but i don't know which one i have to choose.
I found these but will they fit?
vintage-tamiyap...ts_id=1377
Hopefully some of you guys can help me:-)
Thanks in advance.
Jannik
Last edit: by janniklindskov.
Manta Ray shock springs 12 years 8 months ago #27700
The easiest is to use harder oil ;)
Manta Ray shock springs 12 years 8 months ago #27703
I think stock shock oil is around 200-250cw - If you want them a bit harder I'm guessing between 400 and 800cw would work..?
Manta Ray shock springs 12 years 8 months ago #27709
You could also use/move the adjustment ring to ad tension of course.
Not sure TC springs are any harder - and I think that shop is just a database (better look on eBay).
Manta Ray shock springs 12 years 8 months ago #27710
;) MantaEdouray is right. On my shelf queen one I put the ring on the max tension for the rear. And double springs on my runner :evil:
Manta Ray shock springs 12 years 8 months ago #27725
Thanks guys for your input.... I will get some oli and try that.
I have tried to take the tension ring all the way down but i don't think it works.
If i decide to get some new springs, what will you recommend for my?
Regards Jannik
Manta Ray shock springs 12 years 8 months ago #27726
You can test to find some clod buster springs or yellow cva springs for lunch box
Manta Ray shock springs 12 years 8 months ago #27734
Using rear (original) springs on the front might also work.
Time to create page: 0.178 seconds
