I'm back in to the collecting and one of my first goals now I have hoarded a ton of vintage parts is to restore a CS Countach.
I found a quite battered CS on eBay a while back and wanted to share my progress. Original shell condition Replica wing cast from original The start of a repair to the front wheel arch as it had a crack. I have fixed a few she'll with the technique over the years in those points that would be prone to break again. I basically trim down a needle and then get a soldering iron and burry/melt it across the crack. This gives it some real structure back. This is only the start as I will now flattern the access plastic and use car filler to get the original profile back. It's always important to not fill over sharp edges as it will easily crack and trimming a V shape wedge along the line of you crack will help the filler stay in place and not develop a fracture line. I'm yet to trim this around the wheel arch. More to come soon...
Last edit: by Purple_rob.
Casting your own rear wing! That's cool!
I would love to hear more on how you did it! Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
I posted a thread on repro parts below tamiyabase.com/...resin.html |
A small update...
I took out a little more of the cracked line up around the arch. Filled on the front and rear and is now ready for primer. I have done these small parts before any of the other body restoration just to post on here, but hopefully this weekend i'll prime those areas up and post some finished pics. |
Pleased at the new paint and air gun to add to my tools. Black is just a piano black, but I am really chuffed at the Rosso red i had made by paint code at the local paint shop. It is quite a pricey way to do it by the time you have some 2k laquer but I have the Tamiya and 1/12 Doyusha to do.
Now to find the paint code for the blue walter wolf Countach 05 Also bought myself a new A1 cutting mat, its massive and only cost £13 delivered.
I'm hoping great things from this weekend, watch this space.
Needed a couple of vents so just repro'd a pairfor this shell. fresh out the mould and need a clean up... |
