Before a good restauration, (cleaning and rebuilding with some new spares), I want to run with my clio. And easier to run with it than the lunch.
A radio, and a teu 104bk. Soon, I will make a point on my spares body and rims. The matter is that my room is unavailable for several days weeks. So to patient: |
What's up with the foam around the MSC?
Heat insulation ? Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
So, grand mom was checked this afternoon. And she is in healthy.
No big damages. Front shocks upper holes are lightly cracked Ball bearings are lubricated with sand... And good surprise, I forgot that she had aloy 12mm hexagons. The 25teeth GPM motor pinion is in very good condition The ball diff is new (I used the original and I didn't drive a lot after) Gears are nice not dusty like I supposed. Now, I am waiting a new hearth for her and to catch her new body. Maybe a new bearings set and a set of tamiya tires. Pictures will come sooner. Tomorrow surely |
Too fun. And the balancing back.... I love it. |
According to the manual that's the tallest optional gearing (1:6.44), & in general it's better to drop the pinion size when you're going up on the motor - but I think the FF-01 chassis is not very fussy... if it wheelspins from a standing start I think you're good to go Check the motor temperature after a few minutes, the ESC should "thermal" (i.e. shut down in a non destructive way, and be fine once it's cooled down again) |
Thank you Jonny. I will try this combo maybe tomorrow if I have the time with my new job (yes another.... 3 in 16 monthes).
