Hi guys. Am trying to restore my 96 Honda crv cc01 xc 267mm Long wheel base. Looking for anyone who can recommend some new wheels and tyres that will fit under the crv shell. Looking to use it more as a crawler. Also where I might find a replacement roof rack bar or even anyone selling an original shell. Also anyone know of alternative body shell that will fit the 267 wheelbase.
Welcome on TB. For your wheeles you can put f350 hilift ones. A friend of mine did it on his mu.
It's tough to make a crawler out of a CC-01 because the gearing is all wrong. I put an 80T motor in one of mine which does slow it down but it is pretty easy to stall out the motor over rough terrain. A better solution is a GRU (gear reduction unit) but it will require modification of the chassis.
For wheels, any of the RC4WD 1.55" beadlocks fit fine. You can also go 1.9" but you will run into clearance issues unless you use the smallest possible tires. |
