I just thought I would share my Tamiya F201 3 Racing that I rebuilt around 12 years ago, this car has been run on carpet to ensure it is not marked in any way so is in full working order
Parts fitted are as follows (plus I have all the original non 3 racing parts unmarked to restore to oem spec if required inc brand new oem body shell and sticker set) 1 x Tamiya F201 Ferrari Kit Acoms 40MHZ Radio Gear Mtronics RV11 ESC 1 x F201 3Racing Graphite Chassis & Radio Tray 4 x F201 3Racing Swing Shaft 4 x F201 3Racing Damper Arm 2 x F201 3Racing Front Steering Block 2 x F201 3Racing Rear Steering Block 4 x F201 3Racing Ball Nut 1 x F201 Tamiya Turnbuckle Shaft Set Part Number 53513 1 x F201 Tamiya Reinforced Prop Shaft Part Number 53514 2 x F201 Tamiya Tuning Spring sets Part Number 53515 1 x F201 Tamiya High Speed Gear Part Number 53552 1 x F201 Tamiya Lightweight Counter Gears Part Number 53554 2 x F201 Tamiya Front Tyres Type A Part Number 53564 2 x F201 Tamiya Rear Tyres Type A Part Number 53565 4 x F201 Tamiya Aluminium Damper Cylinders Part Number 53566 2 x F201 Tamiya Front Low Friction Dampers Part Number 53567 2 x F201 Tamiya Rear Low Friction Dampers Part Number 53568 4 x F201 Tamiya Alloy Wheel Hubs Part Number 53569 1 x Tamiya RC Super Stock Motor RZ Part Number 53697 Airbox hole cut out to aid cooling I also have a original Tamiya F201 which is in the same condition but this one only has genuine Tamiya parts fitted which includes the following spec 1 x Tamiya F201 Ferrari Kit Acoms 27MHZ Radio Gear Mtronics RV11 ESC 1 x F201 Tamiya Reinforced Prop Shaft Part Number 53514 1 x F201 Tamiya Aluminium Motor Mount Part Number 53518 1 x F201 Tamiya Aluminium Motor Guard Part Number 53524 1 x F201 Tamiya Lightweight Counter Gears Part Number 53554 2 x F201 Tamiya Front Tyres Type A Part Number 53564 2 x F201 Tamiya Rear Tyres Type A Part Number 53565 4 x F201 Tamiya Alloy Wheel Hubs Part Number 53569 I have lots of photos but unsure how to add them. |
Last edit: by AndyAus.
Nice f201.
Welcome, Your most of the way there you just need click the INSERT button after you have uploaded your picture. If you can't fix it with a hammer, you've got an electrical problem mate
