Hey guys just wondering how to remove those very small c rings on the supershot differential gearbox. To remove the dog bone axels.Thinking of very minute expansion pliers or two small screwdrivers to leverage it out. They have been there since 1986 or so. My dad built it with me back then. ☺️ 58054
Thanks Matt |
hi i use a needle from a vintage pocket knife i put the needle in under the c-ring one on one side then i turn the shaft then it raps itself around the shaft itself but it hopes out of the groove then just slowly push the shaft out put your finger on the end so it c ring dont go any where
i been doing tamiya porsche 959 gear boxes a lot because i have 7 of them now lol the vintage needle its a lot thicker then a normal one u buy and the best thing i like it dont damage the c-ring at all needle must be a good size because if its to thick it will reshape the c-ring |
Hello. Spannerman3. Thank you very much for your response and I believe it is definitely useful.
I finally found these little guys hiding In the house cause I knew they were somewhere! They are a set of mini minute flat screwdrivers and a pointy needle. Now I can start. If anything I will try and use a needle itself. Thanks again to you all for the insight. Ps. Great collection of 959’s! I have the 956 mk.5 58042, Supershot 58054 , and hornet 58045. All vintage. Cheers |
