Richard's Boomerang rebuild 2 years 7 months ago #78037
A while ago I purchased a Boomerang from Flo.
Yesterday I fitted new wheels and tires for now.
First part task is to see if I can restore the wheels.
Tires is hard as solid plastic so they was no hope for
Tires was easy to remove, cut a knob of and cut across tire with a flush side cutter and then peeled like a orange.
After 24 hours in grafitti remover, 99% of the paint was gone.
I did scrub them several times with cotton sticks during that time.
Only one outer ring was good enough to keep so I decided to sand them off. What a mess!
My el chipo lathe lol!
Also did the backside. The outher ring was good enough to keep.
That is how far I managed today.
The following user(s) Liked this: stingray-63, Al, 1972 LeMansGT Jim, Ducksnuts, GToddC5
Richard's Boomerang rebuild 2 years 7 months ago #78082
Luv the lathe.  I've done some small scale stuff with Dremel
Richard's Boomerang rebuild 9 months 3 weeks ago #81646
Forgot I had a thread on this...
As you may have seen I have done a few snowruns with this the last few days.
Today I wanted another run before the snow turns to slush.
Was -10C today so both my body and the Boomerang was not happy due to the coldness. Yesterdays -7 felt warm compared to this..
But the car was nearly dead at 7-8min mark, should go for 30min easy.
I had two suspects.
First the on/off switch which was very easy to slide, like no snap stops.
Suspected due to this there was a consumption loss, so I swapped it out for another one.
My next suspect was the vintage Kyosho K-Speed 21T motor I recently installed.
And there it was!
Brushes was nearly completely gone!
Here is the motor
Cleaned and installed a set of these.
My lipo alarm says 7.80V still left and now the motor works good again.
I will also order some bearings for the motor.
If you missed it, here is the driving video.
The following user(s) Liked this: stingray-63, Scanox
Time to create page: 0.675 seconds
