HI!...I started to tear down the "WILD ONE" today. It's going to need a few things. I noticed that the previous owner butchered up the chassis a lot. Drilled holes everywhere.
Last edit: by THE H.P FREAK.
The following user(s) Liked this: dazmax1
HI!... Well I tore down the WILD ONE #2 a few days ago. Everything was going good until I got to the rear gearbox. Apparently the previous owner epoxied the diff gear together to make a "spool". They also drilled "lightening" holes in all the gears. So I ordered a new set of gears. I got new gear box cases and some other small parts. I also got a new chassis. It's a re-re chassis. Tried to get a vintage chassis but all that I could find wanted well over $100 for them. I got this one for $12. LOL! Looks identical physically except for the battery compartment cut out for a stick pack. Just found out that the main roll bars have had mounting brackets cut off of them so I need to order a set of those now as well.
Here's a few pics :
HI!... Well digging through my RC stuff I came across a new WILD ONE complete diff gear and two new aluminum side bevel gears. lol Just got to get the main gear. Also here's some pics of the original chassis that the car came with when I bought it.
Well new gearbox gear showed up from Team CRP this weekend. This is what I have been waiting for so I can start building this thing. As my luck as usual, the gear showed up damaged. A few teeth are buggered up and it has a huge stress crack in it. I contacted Team CRP and their mailing out a new replacement gear. I should have it by this weekend. Also some new parts showed up for this project. New roll cage and front bumper.
HI!... Well the new gear showed up so I started to build the gearbox. It went together pretty easy. Then when I went to mount it into the chassis I realized the previous owner who was drill happy decided to drill a million holes in the plastic support. So now the projects on hold again until the new one shows up. This is what I've got done so far :
