The first car tamiya that I had was a Holiday buggy, purchased in 1982.
After a few years of intensive Exploitation, the car was destroyed! I threw the chassis and body, keeping only the mechanical part throughout. Last year I found a body and a chassis, I reassembled the pieces recovered, repro decals and behold the result. I managed to put on the same radio that mounted. I know it is not anything fancy but I like it, brings me back to youth. |
Looks nice to me
I'm afraid to run these chassis though, having broken an irreplaceable gear in one of them |
Nice fix I'm assuming the brass bit is home turned, but what about the rest of the "Gear B"? I'm guessing the large side is the remains of the original & the small side is a pinion machined down to fit? The one I broke though was the "Gear A", using a 540 motor - different motor mounting bracket & the "Gear B" gets omitted Thanks though - it does give me hope that I can fix it ... assuming I can ever afford a have & somewhere to put it. |
The broken part was the small gear with 15 teeth.
I made ??a brass disk with a pin of sufficient length. I stared hard at disk the large gear, and the aluminum pinion to pin. So I solved my trouble. I hope I explained, the English language is a little difficult for me. |
I have always wondered, what Tamiya was thinking when the left the gearbox open on this car, when it was clearly meant for sand and gravel
I had a Sand Rover as a child, and I woulf love to get my hands on another... My Projects:
