Marui Big Bear 12 years 3 weeks ago #31564
Sorry about the poor mobile phone pictures.
I do have all 4 wheels; just one is not pictured. There are also 2 Big Bear tyres and 2 Lunchbox types.
I did say it was a project :whistle:
Last edit: by Martin Bell.
Marui Big Bear 12 years 3 weeks ago #31565
I got a set of Wild Willy II wheels and tyres which I plan to use on this.
...using these adaptors. I will need to drill the hole out in the centre, but then they should hopefully clamp onto the axle. I will need to drill out the rear wheels too.
Front wheels fit the axles with standard bearings but will need spacers as the axles are far too long.
Marui Big Bear 12 years 3 weeks ago #31566
The white body has been cut, presumably to clear the wheels. Plan is to use this body as a runner and the blue body for the shelf.
My son wants to try his hand at painting, so I will let him loose (with supervision) on the white shell. This one can be "his".
The blue shell I will strip and paint myself.
Marui Big Bear 12 years 3 weeks ago #31571
Crikey :ohmy: bodies have seen the life, have you got a clean window set? I assume you have an interior for you driver to sit? looking forward to your build :)
Marui Big Bear 12 years 3 weeks ago #31573
No and no I'm afraid :laugh:
I'll try and strip the window and see what happens.
There's an interior on ebay, but it's in Oz and expensive. Might try and make one.
Marui Big Bear 12 years 3 weeks ago #31574
Why are they so vulnerable across the back of the body? I've a couple like that on eBay recently too.
Marui Big Bear 12 years 3 weeks ago #31575
I suppose lack of rear bumper and a weak point above the wheel arches.
I plan to add some reinforcement.
Marui Big Bear 12 years 2 weeks ago #31577
:laugh: DAT SUN bodies. I' sure that I have a MSC repair set if you need Martin.
Nice project :y:
Marui Big Bear 12 years 2 weeks ago #31578
Thanks Flo, but I think I'm going to put an ESC in there.
