Had a quick tinker with this today. It needed a diff outdrive yoke, but I found that they are exactly the same as those on my TRX-3 and I had a spare, so on it went. I just need to change the battery connector and it will be a runner (hopefully). I also noticed that the rear track was much wider than the front, and the rear wheels had more offset. Also, there was virtually no steering lock because the front wheels were fouling on the suspension. So, I swapped the F+R wheels and hey presto! the track is the same and it will steer. Looking at it more closely, I am really pleased. It is in great condition (apart from the shell) with only a few scratches on the bottom. It has phenominal suspension travel and the dampers are lovely and smooth. I am sure it will handle more power than the 20T Traxxas brushed motor that is in there, so I am tempted by a mild brushless system when finances permit, and maybe even experimenting with LiPos. I'm also tinkering with the idea of putting my Blackfoot body on it for that scale Tamiya look with unburstable Traxxas mechanics.
Last edit: by Martin Bell.
Took this out for a quick spin yesterday and can confirm that it is a right giggle
It has hilarious amounts of body roll, squat and dive because of the soft suspension, but keeps all the wheels on the ground. Definitely needs more power I've also been thinking about the shell. The standard shell is knackered and it is also very narrow, so it makes the proportions look ever more cartoonish than they really should. I quite fancy a hard body on it, but don't want to spend a lot of money (or any if possible Any other suggestions would be welcomed. |
Took the 'Pede to an
IconicRC meet
over the weekend and was very impressed how it went round the track.
In the words of Monster Truck Madness "Leeeeeean into it!"
BLACKFOOT - TRAXXAS If you can't fix it with a hammer, you've got an electrical problem mate
