Having this heatsink under the chassis being mainly covered by the plastic parts on which the bumper is seated, I'm really doubtful of the real heat dispersion capability... I may be wrong though, and would be really interested to have an temperature measure before and after a run to see if that is having an impact of any sort... In any case this is something I can say is an interesting design somehow...
Ahh, it's covered by plastic on the underside as well. Yeh ok, probably doing diddlysquat. Well, would potentially be dissipating some heat, but not as much as it could be.
Maybe you could design in an opening into the bumper to allow some air flow???
The original Bumper exactly broke where you should add an opening to improve the airflow... Not sure it is a very good idea :-D
Why? Because you can. I asked myself the same question when doing CAD work like all the wiring and pneumatic tubing on this LEGO model. Attachments: |
I like it
After few days of confusion (360), with a lot of model explosions, and a few crashes of the application...
I'm very happy to say I finally succeed to have some progress today First I got one shock. The design is quite similar between the rear and front, everything is the same between the front and rear except the diameter. Copy, paste new, modify sktechs, done. All the shocks done, including the joints, in a separate file and linked... Next was to get everything linked together.... Multiple crashes, a corrupted save, some hiccups in the middle, some explosions again and I now have my car with working suspensions, shocks, and steering working... That was difficult, but I got it. I note for next time that joints used earlier in the process would have definitely helped... I buy kits to built and ru(i)n them
Took the driver set stls from mininguy71 on thingiverse and reworked it to add a driver to my Nichimo. It took a bit of time to understand how to integrate the Mesh in, but I finally have a driver in my car...
Need to work out the airscoop, bodyshell, roof and wing next, and then only things missing will be screws and nuts... I buy kits to built and ru(i)n them
The 21st century spirit. Congrats Marc.
Since I had the driver in, I decided to tackle roof and wing in the afternoon.
I decided to do the roof with Metal Sheet, as I prefer the one from the Exceed than the one from the Spirit FF... Then I did the wing with too much extrusion, bodies and combining them to finish by add fillets I did play crop and resize to 80% on vertical to see if it can look like the box art... I still have to get the bodyshell in... I buy kits to built and ru(i)n them
