I've always loved the look of single seater style buggies, and when I became aware of the 380 motor craze in Japan (and hopefully the UK too) I thought the Scorpion would be the perfect buggy to build. So, here we are. I'm using a few option parts, not not going too crazy due to the relatively low speed. The box art is not suite on Tamiyas level, but iconic nonetheless.
The Ro Mans 380s motor by Pinebeach Raceway. It's going to be rapid... not!
First option part are these heat treated anodised main chassis rails.
I've got a set of shocks from the Turbo Scorpion and as they are slightly longer than the Scorpion you need the shock towers also. Carbon of course.
Next up is the servo saver. I'm replacing the kit plastic part for this beauty.
Progress so far.
The Pinebeach Raceway motor mount to fit the 380 motor to the Scorpion gearbox.
The rear carbon shock mount for the longer Turbo Scorpion dampers.
Gearbox assembled. It comes pre-assembled but I took it all apart and built it back up using my own grease etc.
Next option part. Universal drive shafts.
I thought I'd taken pics of the shock build, but apparently not. Here they are completed.
And, the rear roll bar installed.
On to the front suspension assembly. These cast parts are lovely.
Titanium turnbuckles. As the buggy using trailing arms these are the steering links and front arm braces.
Starting to look like a buggy now.
Optional short style plastic front bumper.
Onto the tub and the electrics. Not 100% decided on a body colour yet, but it won't be box art. I will, however, try to tie it in to the yellow tub.
The rear tyres are soft so I've option for these firm inserts.
And, I've replaced the hard plastic feeling front tyres for these.
I don't usually bother with tyre painting, but as this buggy will be relatively slower than my others, I thought I'd make the effort.
Here's where I'm up to as of today.
The body will be next once the weather improves. I'm hoping to get this ready for the Tamiya Junkies March meet up. Thanks for taking a look.
Well done and gorgeous garage!!
