hsp warhead brushless conversion 13 years 3 months ago #23472
i was thinking of keeping it nitro. i found a cool engine for it
www.hobbyking.c...r_Car.html
hsp warhead brushless conversion 13 years 3 months ago #23493
Looks good but I'd go brushless. Way more interesting modifications (and less noisy too). ;)
hsp warhead brushless conversion 13 years 3 months ago #23503
just bought the brushless motor and gearbox. once i get it running i will get the rest
wooooooo :woohoo:
just need to wait for them to get here
click here to see a ROUGH idea of the motor mount i will make
Last edit: by zephyrin.
hsp warhead brushless conversion 13 years 3 months ago #23507
Nice... very cool 3D link you put there. :y:
A bit like Google Earth. :silly:
hsp warhead brushless conversion 13 years 2 months ago #23591
found some cool wheels
also found these. might be good for a rally car
hsp warhead brushless conversion 13 years 2 months ago #23668
small update
i changed the servo from one that comes with rtr cars to a hitec hs-311
slightly faster and more torque :cheer:
here is a pinion i found
click me
hsp warhead brushless conversion 13 years 2 months ago #23782
found the perfect shell
as you can see i am using the shocks i bought for my wild one as these were much better and i don't run the wo as the drive shafts are worn out
seems i need new wheels
i will lower the shell and make it look cooler
no windscreen and bald tires, those are going to be fixed
hsp warhead brushless conversion 13 years 2 months ago #23784
found the perfect wheels
here is a quick Photoshop of what them might look like
not the right dimensions so don't say they are the wrong size
hsp warhead brushless conversion 13 years 2 months ago #23787
:y:
hsp warhead brushless conversion 13 years 2 months ago #23789
Hey Zephyrin, good work you're doing here :y: However the Jeep body that you have picked up for it (free I hope :) )although the wheelbase will fit your warhead ( within a couple of mm), will need quite some work to get it there. Because of the low bed in the back and the lack of front window you may find that all the hard work you put into fixing and fitting it, will be undone the first time you flip it (especially since its a hard shell) :whistle: I also have a little warhead project on the go and have the same jeep body which I was planning to fit, but have decided that the Jeep body was more suited to a scale project (in the future) I ended up with a stadium truck shell and with not too much fuss, I was able to fit it up nice ;) best part was it only cost $24 delivered from an Aussie seller :y: Also be careful about fitting larger diameter wheels to it, as this will upset the gearing and put more load onto your gears and drive shafts :pinch: good work anyway, looking forward to seeing your progress :) Andy....
Attachment 006800x532.jpg not found
Last edit: by AndyAus.
Time to create page: 0.165 seconds
