hsp warhead brushless conversion 13 years 3 months ago #23296
i'm converting a hsp warhead to brushless
here are the parts i'm getting:
brushless setup
i have a 2200 3s lipo to use, ordered an orangerx t6 because im getting into planes as well.
im going to machine a motor mount at school as we have a mill and scraps of metal
pics soon to come.
any ideas for a pinion?
Last edit: by zephyrin.
hsp warhead brushless conversion 13 years 3 months ago #23303
With some specs like recommended motor ratio, number of teeth on the gears, tyre size and intended terrain we could try to calculate something that might be suitable... certainly an interesting project.
:y:
hsp warhead brushless conversion 13 years 3 months ago #23316
ok, the wheels are the basic buggy ones you get on ebay. i don't know the size and whatever.
the terrain will be like a bmx track, roads, skate parks, the beach.
for the gearing i still have the original 2 speed clutch bell. so i though i woill make 2 sets of holes for the motor mount so one set will be for the lower speed with more torque and the other set will be for the higher speed with less torque
i was also thinking of getting a 1/8 brushless setup but that would destroy the gears so i will probably get a 3000kv brushless with a 45A ESC
link to motor and esc combo
link to a different motor and esc combo
this one has an 80A ESC
i don't know the teeth numbers. i will count when i have the chance
is going to be awesome can't wait B) :P
hsp warhead brushless conversion 13 years 3 months ago #23319
Okay, so the gearing could be kept to buggy spec. :y:
Tyres are usually around 85mm for a 1/10...
Keep us updated, always cool to see an original design. :)
hsp warhead brushless conversion 13 years 3 months ago #23320
Haha, just realised I have of set of tyres for that car (couldn't get them to fit on a Manta Ray). :silly:
Edit - wheels you ordered are 95mm outer diameter... ;)
hsp warhead brushless conversion 13 years 3 months ago #23322
for the motor mount should i machine a block of aluminuim or bend one form thick is sheet metal?
i havn't ordered anything yet, want to see what others think i should get before i order
hsp warhead brushless conversion 13 years 3 months ago #23324
I like the sound of the aluminium motor mount...
The following user(s) Liked this: zephyrin
hsp warhead brushless conversion 13 years 3 months ago #23325
ok then, there is a big cutting head witch would probably be the same size as a 540 or a bit bigger.
hsp warhead brushless conversion 13 years 3 months ago #23441
found an awesome spot to run it once its finished. its a bmx track in the bush
hsp warhead brushless conversion 13 years 3 months ago #23471
i wouldn't mind making it into a short course truck
link to shell
link
link
link
link
link
