custom dune buggy build 14 years 7 months ago #8489
right, i am toying with the idea of building a dune buggy style car from scratch.
minimalistic space frame made from copper tube, soldered together.
has anyone else undertaken such a project and if so is there any plans available to build a chassis or shall i get my pencil and paper out?
the suspension should be easy enough to sort out, maybe getting a gearbox/motor set up may cause a few problems.
something along this design....
Last edit: by agemax. Reason: pic added
Re: custom dune buggy build 14 years 7 months ago #8492
Very cool but ambitious. B)
I'm sure there are examples of builds to be found, like the guys building FOFFs from scratch...
Re: custom dune buggy build 14 years 7 months ago #8494
ermmmmmmmmm i know it will be a challenge but whats an FOFF? :unsure:
Re: custom dune buggy build 14 years 7 months ago #8496
Yes, like it, do it! Please don't use that colour though, it makes it look like that Watanabe Hornet!
see if you can find the real thing & measure it, or download a side+front+rear+top pic & print it on graph paper & scale it, Or have a look about & see if you can find plans for a DIY real one & scale those
Re: custom dune buggy build 14 years 7 months ago #8498
whats an FOFF?
Formula Off Road, awesome sand bashers...
Here's an example - this one's not custom built though :
Re: custom dune buggy build 14 years 7 months ago #8511
guessing i need to work on a battery compartment first and then build around that.
this would give the initial scale/size of how the car would shape up
Re: custom dune buggy build 14 years 6 months ago #8681
Any progress or further plans?
Re: custom dune buggy build 14 years 6 months ago #8682
yeah, got a chassis design in mind. small cockpit stubby kind of front end with BIG exposed shocks.
rear wheel drive probably with a modified hopper gearbox set up as its easy to mount and motor/gearbox is all one combined unit.
modified hopper front suspension wish bones.
probably stock hopper wheels to start with but will probably upgrade fairly quickly
Re: custom dune buggy build 14 years 6 months ago #8683
Sounds good. :y:
I had a look around for a rear DF-01 gearbox but no luck there. That would have also been a good basis.
Just have one for the front that's broken... and of no use, even if it weren't. :S
When you're using your own design, you could really upgrade the rear suspension compared to the Grasshopper. :)
Some sand paddles like on the picture of the FOFF would be nice... B)
Re: custom dune buggy build 14 years 6 months ago #8684
i would like to go to proper independent rear suspension but i dont have a clue what gearbox/motor/drive set up to use
Time to create page: 0.202 seconds
