Re: My little high tech crossmember project 14 years 2 weeks ago #14209
Sorry if I'm a bit late, but have you got the tool for putting the helicoils in? - normally this would be a rod with a slot in the end, but at M2 you might get away with winding the insert onto an old M2 screw & using that as your insertion device. Normally you'd also need a special tap, but again, at M2 & into soft material, I'm guessing you won't need that either...
Re: My little high tech crossmember project 14 years 2 weeks ago #14222
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Nope, don't have any special tools but I was planning on (CA) glueing them in - like I did on the steering more or less.
I reckon the diameter of an M2 helicoil will be about 2.5mm.
With a 3mm hole I can use an old screw inside the helicoil and glue that into the available space quite easily.
If I ever get to receive them helicoils, that is...
Re: My little high tech crossmember project 14 years 2 weeks ago #14233
  • Edou
  • Hopping Mad
  • Hopping Mad
Hey, a birthday present! :cheer:
Suddenly the helicoils are in my mailbox. Must have been given to a neighbour who kept them for three days... :whistle:
Quite happy, even though they're not exactly what I ordered.
I selected the 2.5D version (5.5mm length) and received 1.5D (3mm length).
See if I can work with that though...
Good foresight I didn't cut the stainless rods (to fill up the carbon) to length yet, in case something like this happened.
Re: My little high tech crossmember project 14 years 2 weeks ago #14236
  • Edou
  • Hopping Mad
  • Hopping Mad
I don't think I can work with the 3mms. They're just too short for this purpose. :(
But also : :angry:
What is it about this little project that I get all kinds of stuff that has different specs from what I ordered?
Having to rethink it all and/or yet again order new parts...
Re: My little high tech crossmember project 14 years 2 weeks ago #14237
But also : :angry:
What is it about this little project that I get all kinds of stuff that has different specs from what I ordered?...
It's because the thread you're using has an infelicitous number ... it's 13569 - add the first number to the third (1+5), deduct the second number from the sixth (9-3) and you're left with 666 - the Number of The Beast! :evil:
;) :silly:
Re: My little high tech crossmember project 14 years 2 weeks ago #14238
  • Edou
  • Hopping Mad
  • Hopping Mad
Discovery suggested the beast was Caesar Nero! What's he got to do with my crossmembers? :silly:
But I have to admit this last one (with the helicoils) is due to my own technical ignorance... :whistle:
The 5.5mm spec is the insert length, differing from the length that is measured before useage.
Well communicated by the seller, I have to say.
Since I will not be fitting them in the way they were specifically designed for, I'm gonna have to use small sleeves to get the helicoils a bit deeper inside the hollow carbon - I'll be needing 2mm ID and 3mm OD tube of some sort for that...
Re: My little high tech crossmember project 14 years 2 weeks ago #14239
  • Edou
  • Hopping Mad
  • Hopping Mad
How tiny is that?!
Re: My little high tech crossmember project 14 years 1 week ago #14360
  • Edou
  • Hopping Mad
  • Hopping Mad
This one'll have to go back to the drawing board...
Glueing in M4s on the DF-01 steering assembly was alright but it is not going to work on M2 helicoils.
All started with the carbon tube unexpectedly being the wrong size.
:S
Re: My little high tech crossmember project 14 years 1 week ago #14362
Suggestion - someone else was recently talking about "chemical metal". It's a polyester based 2-pack metal-dust-loaded resin, which can supposidly be drilled & tapped once set. Most brands of the stuff available in the UK are rubbish, but the US version "JB Weld" is fantastic stuff, & does exactly what it says on the packet.
I'm pretty sure if you were to load the ends of your carbon tube with this stuff, then drill & tap it (M2), it should do the job
Re: My little high tech crossmember project 14 years 1 week ago #14364
  • Edou
  • Hopping Mad
  • Hopping Mad
That sounds like something to investigate further. :y:
I think I'd need a proper insertion tool to work with the M2 helicoils...
