hi can i use the tamiya acrylic paints (x xf) as i have load of then also do i need to prep the new body. i have a top force body i need to paint jus to make sure it will be ok as it`s a top force body
jason |
Tamiya X- & XF- paints won't stick to polycarbonate Prep depends on the paint - Tamiya PS aerosols grip very well so all you really need to do is wash the inside of the shell with Fairy liquid, rinse & dry thoroughly ... for other paints (Tamiya PC, other polycarbonate brush paints, Humbrol "Hobby Spray", etc), keying the inside of the bits to be painted (NOT the windows or the outside) with wet & dry paper (then washing thoroughly) will help the paint stick so it's less likely to flake off the first time your roll it or hit something. |
I know this is an old post, but I may have a solution to the X and XF paint issue. We have used Tamiya PS55 flat clear with great success. You paint it on the inside of the body. It will make the body dull, but it is no problem. As soon as you add color, it will clear right up. You only need one coat and remember to mask up the windows. X and XF paint won't adhere to lexan, but it will adhere to other paints.
Nice one I had wondered if that would work; now you can't get the PC- brush paints anymore, using a PS paint as a primer (& finishing with XF paints) is probably the only way you can paint a polycarbonate formed driver (Wild One, etc) with any degree of detail. |
