Thanks for your help |
Rothmans Porsche =
Dimensions and weight Overall length: 377 mm Overall width: 170 mm Overall height 82 mm Wheelbase: 203 mm Tread/track front: 135 mm Tread/track rear: 135 mm Ground clearance: mm Weight ready to run: 0.95 kg Porsche 959 = Dimensions and weight Overall length: 381 mm Overall width: 172 mm Overall height 135 mm Wheelbase: 211 mm Tread/track front: 136 mm Tread/track rear: 136 mm Ground clearance: 25 mm Weight ready to run: 1.60 kg Vanessa's lunchbox = Dimensions and weight Overall length: 385 mm Overall width: 290 mm Overall height 225 mm Wheelbase: 207 mm Tread/track front: 212 mm Tread/track rear: 216 mm Ground clearance: 38 mm Weight ready to run: 2.05 kg All information courtesy of the TamiyaBase Database If you can't fix it with a hammer, you've got an electrical problem mate
Last edit: by AndyAus.
Thanks Andy, I have my 205T16 kyosho body alone and I would like to put a homemade chassis Under.. Maybe with my Pontiac fiero traxxas Idea to research!!! |
