1:10 scale farm machinery scratchbuilds 12 years 3 months ago #29782
Made sense (to me anyway) to move the combine build here ...
Index:
1979 Fiat Trattori 880 DT Pininfarina build
page 1: 1:32 Britains model, RC parts, front axle, chassis basics
page 2: cab drawing, card mockups, drivery hackery, cab basics
page 3: cab & chassis details, interior, tyre mods, nose weights
page 4: priming, painting, final assembly, lights
page 5: fake box art
NC Engineering vacuum slurry tanker with "over-the-hedge" boom
page 5: Britains/ERTL/Tomy 1:32 model, starting frame
page 6: tank skinning, axle & chassis basics
page 7: tank details, paint
page 8: light weathering
1978 Massey Ferguson 760 Combine Harvester]
page 8: Initial plans, Britains 1:32 model clean/rebuild, The Wurzels
page 9: more thinking, line drawings, Clod wheel & tyre narrowing
page 10: rear (steering) axle, 2D card version, chassis, starting on cutting head, conveyor box, starting on reel, reduction box
page 11: battery, motor steady, cutting head ends (dividers etc) detailing, 3D card body/planning
page 12: card body build, translation into styrene, cab, driver, unloader boom
page 13: mk.1 unloader boom mechanism mk.1 fail, turning alloy fake air cleaner, body details, boom mech mk.2
page 14: electrics
page 15: dismantling, primer
page 16: paint & detailing
page 17: fake box art, more thoughts on next project
page 18: test drive fail, posed outdoor shots, diff & 5th wheel mods
page 19: 2nd test drive fail
Back to the original 1st post...
Someone here posted a link to a video of a Tamiya Tumbling Bull bimbling around a farm & that quite tuned me in to the idea of having a 1/10 scale tractor - just not one with an exposed driver, or a lexan body - ruling out either of the Tamiya offerings.
As I'd had a Britains 1/32 scale Fiat 880DT tractor as a nipper the answer was obvious - the 80 series tractor has a very angular shape (especially with the Pininfarina cab) so I wouldn't have to do any difficult curves in styrene, it also fits nicely with by newly discovered fondness for late end of the 70s styling. I can cheat a little on the drivetrain as although the one I'd be using for basic dimensions & scaling is a 4WD model (and how I wish I'd kept mine, the cost of getting a halfway decent one now is best described as "punitive"), there were 2WD models with smaller & wider plain tread front wheels.
So far a quick rootle through the parts heap & a quick bit of spannering on donor chassis has yielded most of the bit I need, including:
- Pajero wheelie gearbox (new gears, apart from a used diff gear from a Wild Willy M38) + shocks
- Lunchkin 10T brass pinion + motor adaptor home made from styrene sheet
- re-re Frog 12mm wheel hex adaptors
- 55T motor from my ORV/Bowler Wildcat scaler
- vintage Sand Rover front wheels & tyres
- Bush Devil rear wheels & tyres
- F103 front upright set
- standard size metal geared servo + lunchkin servo saver
There is a bit of an issue with the wheelbase/width dimensions, working these out from the 1/32 model means the 1:10 version "should" have a wheelbase around 240mm, and 125mm between the tyres on each axle. This would mean I would need to narrow the gearbox - but these dimensions look wrong, with the 150mm needed for the gearbox looking a much better fit.
First step will be to double check, then make a front axle & chassis rails with gearbox & shock mounts ... just not today :)
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #29787
Hmmmm
I'm just wondering how this Fiat will end...I'm sure this thread will be very intresting to follow :y:
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #29800
Good build idea :y:
Hmmm. I have a few Lunchbox gearboxes here... :silly:
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #29821
Good build idea :y:
Build an 8 wheel behemoth? ;)
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #29830
:cry: We lost Jonny in the Tamiya's badword!!! :y:
Very good idea JR :silly: You are definitively crazy
Last edit: by stingray-63.
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #29847
Get yourself on youtube & look at some RC tractor pulling - should whet your appetite for tractor-related silliness (Some of them are using gas turbines too!).
Went to Weeting steam rally today, spotted an old Fordson which someone had grafted a Perkis V8 into... suspect that wasn't to make it better for dragging ploughs, more likely sleds.
There's a rally in South Wales (Great Malvern? something like that) that still does tractor pulling - V entertaining! Only time I've ever seen steam traction engines pulling wheelies!
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #30084
Made a bit of a start on the chassis, need to get some more 8mm (5/16ths") square aluminium bar to make some servo mount blocks (same two screws will hold the front axle on) and make some sort of bracketry for the rear shocks ...
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #30085
Too hard for me jonny but a nice chassis :woohoo:
1979 Fiat Trattori 880 DT Pininfarina build 12 years 3 months ago #30094
Very nice work again (twas me by the way who linked to the rather brilliant Tumbling Bull video from a TC member). :y:
1979 Fiat Trattori 880 DT Pininfarina build 12 years 2 months ago #30170
I've spent a little more time on this - making some servo blocks & finishing up the steering, and also making the rear suspension mounts - most of which should be hidden under bodywork a lot later on :)
