I spotted this unfinished project on eBay - as you can see it started out as a vintage Sand Scorcher body, and if you can look past the dirt & grot, it's had quite a lot of interesting (and involved) detail work done on it - chopped & smoothed rear end, doors bulked out & showing insides, fuel filler capcut out & boxed in, partial wheelwells, etc etc. It looks like it became a test piece for various paint effects & colours, before finially beaing abandoned to the dust & creepy crawlies.
I also bought an unfinished steel sand rail from the same seller, and (partially) because they were listed separately - but more because I _wanted_ them to fit together (i.e. not the sellers' fault at all) I assuemd they would - and of course, seeing them together it's obvious I was completely wrong on that score. ... _However_, as the SRB chassis is very floppy without the bracing effect of a shell fitted (and/or top plate, a la Super Champ), it makes sense to have a metal chassis - so it wasn't quite as daft a buy as it first appears. It has great patina, so once I've cut off the cage, ground back some of the pigeon poo welding & waited for the fresh bits to rust up again, I'll try to preserve it rather than strip, de-rust & repaint it. The first job though will be to wash the body tub down, and try and sand off as much of the paint & primer as possible ... after that, I have a re-re Scorcher body set that will donate the bonnet (hood) and nose, obviously it needs a windscreen surround, roll cage, driver & minimal interior, a floor, some way of holding the body on, and of course SRB front & rear ends. It would be nice to get a decent donor chassis for this, but I'm looking at my "Budget Bug" build in the meantime... I'm hoping modern electrics (2.4ghz RX & small ESC) can be hidden under the bonnet, maybe even a small capacity 2S Lipo battery too |
That looks like a really nice basis for your project.
I've rebuilt two 1:1 Beetles (tear down into atoms, and back up again) in the past, and that body looks pretty similar to the real thing. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Lars, you made this Bug??? |
That could work |
Cage cuf off the chassis, worst welds ground down (though not completely), shiny bits wetted & table salt dabbed on to try to encourage rusting to match ...
In the meantime I've shuffled lots of SRB bit around - the rear cage is a must as the proportions loked wrong without it, though the body will need modifying to make space for the pipe joints & rear dampers. I'm not 100% sold on the front cage - but I needed something to hold the nose in place Lots of work ahead - the idea is the easy bit
I'm really impressed with the amount of work the PO put in to the interior detailing of that body, It's a shame they never completed it. Luckily for us it has ended up with you JR & I'm sure the final result will be wonderful
Steel chassis extends the wheelbase to 40mm longer than stock, which means extending the body. The obvious place to do it would be at the B-pillar (i.e. behind the doors), so I'm going to extend the bonnet instead & have made a start on that, butchering a previously NIP re-release Scorcher body to do so
