You might need to check the part #, as the parts database doesn't show 50619 as CVA Dampers.
Measure the current shock mounting holes center-center. I've got a regular M-05, so not exactly sure how much it shares with the Ra version. Sounds like the Ra achieves the extra 5mm clearance with just different hubs/knuckles, and the shocks are most likely the same? I also put stiffer (blue) springs in the rear, as found them too soft for a FWD. But this would depend if are going to run on road or dirt. tamiyabase.com/...6213-53440 - they are for TA/TL chassis, so you need to use a spacer to take up the slack.
I ordered these for my m-06, will report when i installed and tested them.
Yeah racing 55mm shock absorbers
Only difference with Ra is with the hub knuckle. I don't know why these are not in the M-05 kit as standard as there is two settings, standard or the extra 5mm ride height.
Thank you |
Keep us updated.
Thank you |
I ordered the same shocks as lem. And they fits very well on m05 and mf01x.
50519 or 50619?
Kind Regards |
I've got these for my M06, which are apparently 50mm: tamiyabase.com/...7949-54000
Coincidently, I got those same Yeah Racing shocks for my TT02. They are 55mm. Haven't built either chassis yet. Then there's the cheaper options like these: ebay.com.au/itm/403407842179?hash=item5decfb2b83:g:mFMAAOSweqVh3711
Last edit: by Ducksnuts.
Thank you
The M-05R version of the chassis comes with the
42273
TRF dampers. These are the top of the line if you want the best Tamiya offers. I describe them on my
Mini Cooper
build. The
54000
aluminum dampers also work (cheaper), as do the
50746
CVA Super Mini plastic CVA dampers (cheapest). The two metal sets come with 4 dampers, but you'll need to buy two sets if you get the plastic version. I describe the 54000 set on my
Renault Alpine
build, and the CVA version are used on my
Rally Beetle
build.
