Index
Page 1: "wooden" crate, cooler box, "barn" style toolbox, basic instrument case Page 2: Ammo boxes & more crates; weathering - dry brushing & washes; mk.1 Tool chests Page 3: finished tool chest; shelving unit & bench; mk.1 oxy-acetylene kit & TIG welder Page 4: finished mk.1 oxy-acetylene kit & TIG welder[/url] Page 5 Page 6: Fuel Cells started Page 7: Radiators started Page 8: Radiators continued, mk.2 welding kit started Page 9: Radiator epic fail, mk.2 welding kit & fuel cells finished, pallets Page 10 Page 11: Axle stands, trolley jack, cable & hose reels, Haynes manuals Page 12: Bench pillar drill Page 13: Lathe started Page 14: Lathe finished Page 15: Bench Grinder, beer cans & fridge started Page 16: Fridge finished Page 17: Henry Hoover, Compressor started Page 18: Compressor finished, fire extinguishers & stand, pile of wood, grease tubs, air filter/oil filter/disposable gloves boxes Page 19: Garage started Page 20: Garage construction finished Page 21: Garage sprayed Page 22: Garage door & walls detail painted/weathered Page 23: RIB (Rigid Inflatable Boat) started Page 24: RIB construction finished, paint (incl. wood & rubber effects) Page 25: Skip (dumpster) & fill Page 26: skip fill finished, starter trolley & pressure washer started Page 27: bungees, office chairs started Page 28: lockers & desks started Page 29: laptops; + lockers & desks painted Page 30: TARDIS, plank outhouse, simple canoe Page 31:Outhouse barrel (& contents Page 32: Beetle shell started (plus narrowing/reducing radius on tyres) Page 33: Beetle continued (front suspension assembly, door inners, chassis) Page 34: Beetle continued (primer, not entirely succesful salt effect) Page 35: Beetle finished Page 36: Ramps, Batteries started. Engine hoist, mechanics creeper & stool + tyre rack finally finished Page 37: Strip lights, batteries finished Page 38: More barrels (& manual lift pumps), oil drain setup, oil pouring jugs, tyre balancer started (but never finished), battery rack, 4-post lift, mocking up Willy's business diorama (and same in MDF), smaller axle stands, pneumatic nut drivers, buckets, trolley jacks, railings, more filter boxes, ceiling tiles & architrave/skirting boards, posters & banners, more euro pallets, reel rack & filter storage Page 39: Mk.3 tool chest, small mechanics stool, fire extinguisher mods, basic spanners, bulkhead lights, inspection lamps, starting on exhausts, desk phones Page 40: Carpet, office finished, painting of page 38-39 items, filling fire buckets, basic dirtying of floor, lighting wiring & test Page 41: final setup of Willy's Garage edit ends Not sure if this is the right place, but here goes ... I like to see bits & bobs on the roof of a scaler - but I don't want to pay the huge amounts the few bits available cost - which will then look the same as everyone elses... at the moment I have a "cheap" cast resin oil drum, toolbox & inappropriate set of spare wheel on the roof of my Frog-based (really) Bowler Wildcat - but having a big pile of styrene sheet & some time on my hands, I thought I'd have a go at making some boxes - this is where I've got to so far: First up, a "wooden" crate ... I cut up some sheet for the "plywood" sides - 3mm, for strength ... probably over the top - it's resulted in a crate that I (or any two regular people) could stand on ... added 1.5mm sheet top & bottom, sanded it with 240 grit wet & dry in one direction, the idea being I'd get some wood grain effect going on, then added strips of pre-sanded 1.5mm sheet for the "wood": I thought I'd also try a "plastic" cooler box - construction was the same as the crate to start, but with careful attention to getting rounded edges on the sides & base (used 240 grit then 800 grit) - then used "Squadron White" putty to fill any gaps ... I wanted to try a guitar case (think "Desperado" rather than James Blunt |
Last edit: by Jonny Retro. Reason: more pages for index :)
... and jsut in case anyone forgot what primer looks like
... seriously though, it's only once you start to put primer on something that you get to see how well (or not) it's going to work - I'm pleased with the cooler, fairly happy with the crate - but the toolbox & instrument case needed more detail. |
It is so cool to see your work on these little things!
Are they going on the XR311 or something else? -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
They'll be going on top of the world's least capable scaler - my Frog based Bowler Wildcat These are some old photos, I've fiddled with it since ... |
Finished this batch ...
Instrument case is semi gloss black, dry brushed with dark grey, aluminium & brown details ... Toolbox is 3 coats of flat red, 1 of gloss, aluminium dry brushing ... Cooler is 3 coats of flat white, one of gloss, 1 coat of flat blue & one of gloss ... which I should have thinned down a bit ... Crate is 2 coats of buff, dry brushed with flat earth, dark grey & NATO brown, washed with med grey & buff I'm going to try a few ammo boxes & ammo crates next |
Very nice painting and detailing!
I wish you could make a step by step guide to painting like this... -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
I "Installed" the new boxes ... the disadvantage of not having a proper roof rack is you really have to make sure everything is tied down properly
It all stayed on all right though - several quite hard thumps, 2 occasions of parking it on it's roof, and multiple getting stuck-ages ... Which is more than can be said for the left "headlight" |
