Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5695
things cheap enough for resale
You're right, it doesn't offer enough margin for that.
I'm a bit confused about the great variety in prices. :huh:
Not sure what that's about...
But in general it's a very cool technical development that'll probably get cheaper in the (near) future.
And already interesting for some applications. :)
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5791
Started on some "fuel cells":
3mm styrene "frames":
1.5mm styrene tops (& bottoms):
Filler:
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5792
... And talking of filler, this is a tube I bought very recently off eBay - the seller was very good about replacing it, but I can't help thinking they should have picked up on it when they picked/packed it ....
Tear in tube ...
... let all the solvent out, solidifying the contents:
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5798
Mmm... are those teeth marks? :huh:
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5803
JR - You are a LEGEND...
You are a total inspiration to me, Thank you dude...
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5813
Boxes sanded ...
Material cost so far:
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5814
Took me 4 attempts to get the M2 cap head screw spacing right...
M5 bolt will be replaced with a cap head bolt ...
Have to work on the pipe feed plate next :)
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5816
Simplest is usually best, so the "fuel line connection" plate is a simple round of 1.5mm sheet with 3 holes in it, more M2 screws & nuts. "Fuel line" will be silicone sleeve in green, red & black (for the 3 connectors - fuel, fuel return, and vent)... I'm thinking 330mm long should cover most eventualities.
Only made the one prototype thus far, need to have a break & a tidy up as I'm getting frustrated with "loosing" stuff in plain sight :S
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5818
:woohoo: Speechless :woohoo: Overwhelmed :woohoo:
Re: Scale boxes & toolchest, + weathering 14 years 9 months ago #5821
Don't get too excited, only one of the taller ones is for you ;)
I need to get some more primer & wait for some supplies before I can do any more on the fuel safes, so i've started on the rad ...
Time to create page: 0.837 seconds
