Hello.
Arrma Big rock 4S Freestyle Bash On a hot day, the ESC overheats. I'll have to play with it slowly. Arrma Big rock crew cab V3 -Part upgrade- ESC : Hobbywing EZRUN MAX10 SCT 120A Motor : Hobbywing EZRUN 3660SL G2 Brushless motor 3200KV Tire : Pro-Line Racing Trencher HP 2.8" All Terrain BELTED Truck Tires Mounted, AP6336 6x30 to 17mm Hex Adapters Battery : DXF 8400mah 120c 4s Gear : 32DP Motor Pinions Gear for 5mm shaft - 15T Shock : GPM Aluminum rear heavy-duty adjustable damper (front 102MM, rear 115MM) Whee Nuts : Aluminum Wheel hubs 17mm Hex Nuts |
