Hello.
X-Max I did a sandstorm driving in a wide area. There was a lot of sand and dust, but the stress was relieved and it felt good. Traxxas X-Maxx 8s ESC : Hobbywing EzRun MAX6 Motor : Hobbywing EzRun 4985 SL 1650KV brushless motor Servo : POWER HD WH 65KG Digital Servo Metal Gear Tire : Pro-Line Racing Badlands MX43 Battery : DXF 8400mah 120c 4s X 2 Body : Pro-Line Racing Pre-Cut Brute Bash Armor Body (White) Gear : 20/50 Spring : Pro-Line Racing Dual Rate Spring Assortment Motor mount : JH Racing CNC aluminum alloy motor fixing bracket Tie Rod : NEW ENRON Aluminum 46MM Servo Steering Linkage Tie Rod - PART - RPM 80662 Oversized Front Axle Carriers RPM 81732 Oversized Rear Axle Carriers
