Weather was perfect today with crisp -7C!
First run cut short due a couple of issues, then the fun began As you can see my front diff issue is fixed. All it took was fitting a E clip insted of C clip on the right side as the orginal C clip allowed too much slack when fitted with bearings. The Kyosho K-Speed 21T could use some bearings as the bushings seems to go dry fast, hence the little scream you hear. Lipo alarm did come in a few times, but false alarm as voltage was still good. Sometimes the old electrics draw a litte too much current which trigger the lipo alarm. Setup in this video: Orginal vintage Boomerang with bearings Kyosho K-Speed 21T motor Stock MSC Losi 2.4 receiver Gens Ace 4000mAh 2s lipo battery with lipo alarm. Would had longer runtime if I had charged it fully (only 3200 of 4000mAh filled), but I wanted to drive before dark. |
A fast old boom drifter🤗❤🥰
