Hi you all
I |
Last edit: by trf_414_m2.
This looks really cool!
But, I cant find any information on who is producing it. I used Google Translate and cut and paste the japanse text from the PDF and got this: (from top down) [code] "Sound Exhaust System" Limited! ! Pal the item appeared in plays electric car engine sounds! ! - the engine sound generation according to driving speed. - generates little noise into the throttle and idling, speed up and go Shift, slow down and shift down (stage 3) - volume, shift points, each volume can be adjusted by pitch. We brush motor with ?. Accessories - Sound system unit Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Thanks Lars. I did the same when I saw the item, tried to contact these guys but still no answer. The Speed Way Pal sound generator features same case and external shape as the Straight Exhaust Sounder produced some years ago. This "sounder" feature different chips, maybe for 4 gears shift up and down, while Speed Way one shifts 3 up and down only (as I |
