Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78786
  • blakbird
  • Impressive Numbers
The story of the Tamiya TRF 414 racing touring car chassis is convoluted and difficult to follow.  Many of the models in the line are rare to the point of being almost imaginary, with some never being available to the public at all and those that exist almost impossible to find.  This makes the history very difficult to chase down.  It seemed to start with the TRF 404X prototype in Japan in 1998, a car that never had a model number and was never available for sale.  From there we got the 93013 TRF 414X in 1999, a limited edition model only available to racers in the USA.  I managed to get my hands on one and wrote about it in another topic .  That morphed into the 49132 TRF 414 in 2000, another limited edition model that this time was somewhat more widely available (but limited to 750 units) and incorporated quite a few improvements from the original.  The first widely available production model (though still limited edition with unknown production numbers) was the 49175 TRF 414M in 2001 which had lots more changes. Finally, the 49219 TRF 414M-II came out in 2002 with a handful of additional improvements, most noticeably the first introduction of the now familiar Tamiya blue anodizing.  I present a detailed list of the changes to each generation of the model below.
That's still not the end of the story though.  There were also a number of conversion packs and special editions to round out the product line.  49173 was a parts pack which allowed owners of the TRF 414 to convert it to a 414M.  Given that only 750 copies of the TRF 414 existed in the first place, the market for this conversion kit was pretty small.  The 49220 Champion Memorial was a special edition of the TRF 414M-II which included a Dodge Stratus body with a wing from Protoform and some upgraded swing shafts.  I was never able to find a manual for this model (I don't think it had a unique manual) so my information is limited to that inferred from a picture of the label on the box.  Much more information is available on the 49255 World Champion Replica kit from 4 months later.  This model is a version of the TRF 414M-II based on Surikarn's IFMAR ISTC1 world champion winning model from 2002.  It includes the specific settings and modifications Surikarn used in his race winning car and the same Protoform body as the Champion Memorial edition.  The most obvious changed parts are the pocketed bulkheads for reduced weight, an alternate front anti-sway bar installation method, simpler shock towers, and elimination of the radius arms.  These special sets were individually numbered out of a total production run of 1700.  The model I managed to get my hands on is a standard TRF 414M which was very interesting to compare to my TRF 414X prototype.  I'm guessing very few people have had the opportunity to put them side by side.
1 International Federation of Model Automobile Racing, International Scale Touring Car class
TRF 414 Changes
  • Injection molded parts C (knuckles), D (suspension arms), E (uprights), and F (C-hubs) added in place of machined aluminum (C, E, F) or machined plastic (D)
  • Lower chassis plate modified slightly to add holes for aluminum steering servo mounts instead of servo tape
  • Upper chassis plate changed to symmetric design
  • Shorter front drive cups
  • Straighter rear carbon hinge pin mount with smaller skid angle adjustment
  • 4x rear CVDs instead of different style for front
  • New style setting wheel with less material
  • 4x thin wheel hexes instead of thinner for rear
  • One fewer o-ring and extra rod guide in each shock
  • Two-piece kingpins with separate bushing
TRF 414M Changes
  • Stretched wheelbase
  • Accommodation for standard stick battery
  • Threaded shock bodies for two-piece adjustable spring collar
  • New suspension mounts
  • New rebuildable CVDs without pressed pins
  • New dish wheels instead of setting wheels
  • Most 6mm ball connectors replaced with 5mm
  • 0.4mod gears instead of 64p
  • Updated bulkheads with separate motor mount
  • New heat sink bulkhead spacer
  • Modified shock towers
  • Molded pulleys instead of aluminum
  • New two-piece front one-way
  • New diff joints
  • Standard front and rear sway bars
  • Hex hardware
  • Radius arms
  • Proper build manual instead of exploded views
TRF 414M-II Changes
  • All aluminum parts anodized in blue
  • Rear lower suspension arm spacers moved resulting in 4.7mm wheelbase reduction
  • Ball diff drive cups reinforced
  • Updated turnbuckle shafts
  • Single piece threaded spring perches
  • Wheels and tires no longer included
  • Alternate suspension arms no longer included
Like all the TRF touring car chassis, this a twin belt driven 4WD model with carbon fiber chassis plates, loads of machined aluminum parts, and generally the best parts Tamiya could come up with including hardware and axles.  The result is a beautiful (and expensive) work of art.  Although my standard rule is to drive all my models, given the rarity of these particular chassis (and the fact that I have lots of other touring cars to drive), I have to break precedent and keep these pristine.  Future generations will thank me.
The TRF 414M comes in a small box with a carrying handle like many standalone chassis.  There is no box art on this kind of box, instead there is a sticker on the side with the relevant details about the model and a picture.  This version of the chassis is also printed with some information on the front cover (in English).  Finding one of these still sealed in the box was a real accomplishment.
When the box is opened all you see is a layer of bubble wrap enclosing and protecting all the parts.  Once that is removed you can see the plastic parts, hardware, and other parts.  Note that unlike many of Tamiya's high end chassis, this one comes with wheels and tires.  No body though.
Because TRF kits don't come with a body, the sticker sheet doesn't represent any particular livery.  These TRF 414M stickers are unique to this model.
The photo on the left shows all of the parts laid out on my table, but still within their internal packaging.  Some of the plastic trees are individually bagged, as is the chassis.  The largest bag is reserved for all the hardware which is not separated into step groups.  Everything must be opened at once.  On the right I've knolled all the parts, set out the manual, and have prepared to start the build.  Unlike the TRF 414X, this one has a proper manual.
The following user(s) Liked this: stingray-63, AndyAus, 1972 LeMansGT Jim, GToddC5
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78790
  • blakbird
Since I have already written about the build of the original TRF 414X chassis in great detail, I am going to concentrate on the differences when writing about the TRF 414M here.  Please see my TRF 414X topic for more details on the original.
I prepared these images comparing the TRF 414X chassis plate (black) to the TRF 414 version (blue) and the TRF 414M version (red) using extractions from the manual and overlaying them.  You can see that there are many similarities, but the primary difference is the increased length on the TRF 414M.  You can also see the addition of a mounting flange so the steering servo can be attached to both updated chassis.  In all cases the 6 rectangular slots are to allow individual battery cells to sit low and the large rectangular slot in the rear (right hand side) is for the motor.
While the TRF 414X started by building the differentials and bulkheads and adds the suspension later, the TRF414M separates the suspension mounts from the bulkheads so they can be installed first.  This requires many more holes in the chassis plate as can be seen in the previous chassis comparison images.  The images below show the installation of the inner aluminum suspension mounts (they were Nylon on the 414X) and the steering posts.
The TRF 414X suspension arms were machined from blocks of Nylon, but here we have carbon fiber filled molded arms which are much stiffer.  The hinge pins of the 414X just slipped through holes in the suspension mounts, but here there are ball joints on the ends of the hinge pins which fit into machined pockets in the mounts.  The anti-squat angle (incline of the hinge pin) can be adjusted by adding or removing spacers under the suspension mounts differentially.  By default the front mount uses 0.7mm spacers and the rear mount uses none resulting in a slight incline.  The roll center can be adjusted by adding or removing spacers under the suspension mounts symmetrically.  The toe angle of the rear suspension is fixed by the geometry of the uprights at 2° using identical front and rear suspension mounts, but can be modified to 2.5° by changing to a slightly wider rear mount.  Ground clearance can be adjusted by turning the set screw in the front inner corner of the arms which restricts their maximum travel by contacting the chassis plate.  In general there is more adjustability here than on the 414X and it is easier to perform changes.Note that most of the "new" plastic parts including the arms, the uprights, the knuckles, the hub carriers, and the pulleys are actually from the TA-04.
Now we can do the same thing for the front suspension.  The assembly is pretty much the same as the rear.  There is no front sweep angle in the suspension arms since the toe is intended to be adjusted by changing the length of the steering links instead.  Note that small changes in wheelbase can be accommodated by moving the spacers on the hinge pin.  There are 4.7mm of spacers used on both the front and the rear with the arms biased toward the rear by default in both cases.  The kick-up angle of the front arms is the same as the rear using 0.7mm spacers under the front suspension mount.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78791
  • blakbird
Time to build the rear ball differential.  The pulley has the same number of teeth (32) and uses the same number (10) and size (3mm) of balls as that of the TRF 414X, but now the pulley is molded plastic instead of aluminum so it doesn't need Delrin inserts for the balls.  The steel drive cups are machined from smaller diameter bars by using plastic housings to adapt to the pressure plates.  All of this tends to reduce the rotating mass (but it's not as cool).
The front one-way is built using separate one-way bearing housings for the left and right axles, as opposed to the TRF 414X which used a single housing with two one-way bearings in it.  While the 414X used a different pulley for the front one-way, the 414M uses the same ball diff pulley used in the rear and just bolts the bearing housings to it as shown.
The rear machined bulkheads look quite different than those used on the TRF 414X.  The overall geometry is the same and the bearings are still pressed into the bulkheads from the factory, but now the motor mount has been removed into a separate part and the suspension blocks are no longer mounted directly to the bulkheads.  This results in bulkheads which look a lot thinner and less substantial than before.  The motor, center pulley, and rear axle all end up in the same place though.  The lateral stiffener has also has some cooling fins added.  They probably don't do anything, but they look important.
Here is the completed rear bulkhead assembly both before and after being installed onto the chassis.  One subtle difference is that adjustability of the motor position for pinion mesh was vertical on the 414X and is now horizontal on the 414M.  This is why the motor clearance slot in the chassis plate had to be made a bit wider.  Note how the suspension mounts are now completely independent from the bulkhead allowing them to be altered without removing the driveline.  Likewise the ball differential can be removed for maintenance without disassembling the entire suspension.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78792
  • blakbird
The front bulkhead has fewer differences from the TRF 414X than the rear, but the suspension blocks have still been removed from the assembly.  An exploded view is shown on the left and the installed assembly on the right.
The center pulley assembly goes together very much like the TRF 414X with a 15T pulley locked to the shaft to drive the rear axle and a one-way to drive the front axle.  The main difference is that now the pulleys are plastic instead of aluminum.  There is still no way to directly adjust belt tension since all the pulleys are locked in position.
The TRF 414X did not come with any anti-roll bars, but the 414M comes with 3 full sets of front and rear bars with different diameters (red=soft, yellow=medium, blue=hard).  These pivot on the bulkheads and connect to the lower suspension arms with ball joints.  Unfortunately I found that because of the amount of play in the bulkhead pivots, the bars are not really effective at communicating suspension position between left and right sides.  Later generations of TRF chassis would fix this problem by adding set screws to the pivot brackets allowing the builder to adjust for a snug fit.
The TRF 414X used CVD style drive shafts which were pre-assembled, but here we have individual components retained by set screws instead of press fit of the pins.  Much easier maintenance this way.  The biggest obvious difference is that the new rear uprights are now carbon reinforced plastic parts instead of aluminum, but with the same basic geometry.  There are now two hole options for attaching the camber link instead of one.  The same narrow hexes with o-ring pin retainers are used.  If you look closely at the right hand image you can see the 2° toe angle label molded right into the upright body.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78793
This thread is crazy. I recon several parts used on ta04 and ta05 I had. And a lot of sparts I had when I bought my db01r.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78794
  • blakbird
There are a lot of similarities between the TRF 414 and the TA-04.  I'll show some comparison pictures at the end.  Especially if you compare to the TA-04 TRF, it is almost the same except TA-04 has more plastic instead of aluminum.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78812
  • blakbird
Here I've assembled the rear uprights with their bearings and axles.  On the right I've completed the rear suspension by installing the axles and camber links.  The anti-sway bar just fits in the space between the rotating axle and the upper link.
Like the rear suspension, the biggest change in the front suspension from the TRF 414X is replacing the aluminum hub carriers and knuckles with plastic parts.  This does much to reduce the unsprung weight without sacrificing too much strength.  The lower kingpin now gets a sleeve to rotate on while the upper kingpin gets an integral ball joint instead of having the ball at a separate location which results in a higher upper suspension link.
The complex looking steering assemblies are shown completed at the left.  These are pinned into the lower arms and then the front suspension is completed by adding the upper camber links as shown.  The attachment of the anti-sway bars is somewhat different than in the rear.
The steering bellcranks (aluminum) and bridge (carbon fiber) appear to be the same parts from the TRF 414X, but the rod ends are now the closed ball type with smaller 5mm balls.  The assembly has to be passed between the upper and lower parts of the belt and then slipped over the steering posts.  While the 414X had all 10mm worth of spacers on top of the cranks, the 414M moves the cranks up by putting 4mm of spacers beneath the cranks and the remaining 6mm on top.  I've actually got this wrong in the picture on the right, an error I discovered and corrected later.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78813
  • blakbird
The upper chassis deck has been modified from the TRF 414X to be a symmetric design, but is otherwise quite equivalent in shape and stiffness.  A bigger difference is the addition of these plastic supports to allow the use of a standard 7.2V stick battery pack mounted laterally.  It is still possible to mount individual cells in a saddle configuration but required that the mounting tabs for the plastic supports be manually trimmed off the chassis plate.  No thanks.  I'll stick with the brackets.
Here's a detail that didn't exist at all on the TRF 414X: radius arms for the front suspension.  Given that the front one-way prevents any braking forces from being applied to the front wheels, I'm a bit surprised these were necessary.  Still, they certainly result in much improved longitudinal stiffness.  The additional parts shown on the left are for a new belt support.
From this side view you can see the new ball bearing belt support.  The manual titles this a "tension pulley".  While it does add a bit of tension to the belt, it is not adjustable.  It does provide some support to prevent the belt from "slapping" at high speed though.  The increase in belt height driven by this pulley is why the steering cranks needed to be raised 4mm.
The shocks have been modified a bit from those on the TRF 414X.  Apart from the obvious difference in color, these new shocks now have a threaded body which allows the use of a movable spring perch for easy preload adjustment instead of using spacers.  There is also one fewer o-ring which has been replaced with a rod guide, a urethane bushing has been added above the bladder, and the number of holes in the piston has increased from 2 to 3.  While the TRF 414X came with 3 sets of springs with different rates, only a single set is included here which also means the same stiffness has to be used on the front and rear.  These seem equivalent to the stiff rate springs from the 414X.  The carbon shock towers are shown on the right.  They share the same overall proportions as those from the 414X but have fewer holes.  Note that the 6 outer lower holes on each tower which were used for camber link attachment options on the 414X are actually not used at all on the 414M; the links attach directly to the bulkheads.
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78814
  • blakbird
Here the shocks and towers have been installed to the front and rear suspensions on the chassis.  The only difference between the configuration of front and rear is the amount of default preload applied to the springs (1mm in front, 3mm in rear).
The TRF 414X used a 120T 64p spur gear from Kimbrough.  This time they included 3 Tamiya options using metric 0.4mod pitch instead: 112T, 120T, and 128T.  This allows a greater variability in available gear ratios because both the pinion tooth count and the spur tooth count can be varied.  The massive amount of adjustability varies from a final drive ratio of 4.98:1 (112T spur with 48T pinion) to 10.92:1 (128T spur with 25T pinion).  The default configuration uses a middle ratio of 6.40:1 (120T spur with 40T pinion).  The 414X used a 35T pinion for comparison so the 414M is geared for more speed out of the box.
Note that 0.4mod = 63.5p so the two pitches are functionally interchangeable, though not technically identical.
I've added a standard silver can motor here just to fill the space.  I don't plan to run this model.
The TRF 414X and 414M use the same high torque servo saver, but whereas the 414X steering servo had to be installed with foam tape, the 414M adds aluminum mounting posts and provisions on the chassis to attach them.  This is a vastly superior system and was one of the few complaints I had about the 414X.
The body posts and foam bumper are carried over from the TRF 414X, but the bumper mount has had some strengthening ribs added.  The completed rolling chassis is shown on the right (without a speed controller, receiver, or battery).
Blakbird's 49175 TRF 414M Build and History 2 years 3 months ago #78815
  • blakbird
The TRF 414X came with aluminum setting dishes but no wheels or tires.  The 414M flips this around and comes with new 24mm wheels, tires, and inserts.  Everything is installed and completed as shown on the right.
The tires and foams are not Tamiya parts and have no part numbers in the manual.  The tires are from Sorex (probably 36R) and the foams probably are as well since they don't match the coloring of Tamiya inserts.  All 4 dish wheels are the same and have 0 offset.  If you zoom in on the sprue for the wheels you can see that they are stamped 49175 and were therefore new for this model.  These would continue to be used for many years.
Time to create page: 0.272 seconds
