The fourth generation of the TRF touring car line began in December of 2010 with the 42184 TRF 417 chassis one year after the last version of the previous generation (TRF 416X) at exactly the same price point. Compared to the TRF 416X, the primary differences are related to being setup for more modern electronics including rectangular hard pack batteries and brushless motors. The first update came out the following June and was designated 42200 with the only change being the addition of a rear gear differential in place of a ball differential making it really just a standard TRF 417 with optional parts included. The following December (one year from the initial model) Tamiya released the 42205 TRF 417X which incorporated the same gear differential and minimal other changes and simplifications. In July of 2012 Tamiya released a special edition, the 42235 TRF 417X Reedy Race Victory Commemoration set. This version was based on the changes driver Viktor Wilck made to win the 2012 Reedy International Touring Car Race of Champions. Information on this version is very sparse (I was never able to find a manual). It came in a standard TRF 417X box with an extra sticker on the cover and only cost an additional ¥10,000. Anecdotal data suggests that the only changes may have been a different sticker sheet and an optional front gear differential in which case it probably had no unique manual. This limited edition set had apparently only 200 copies produced. Finally, in December of 2012 (2 years from the initial model) Tamiya released the final version which was designated the 42240 TRF 417 V5 (the fifth generation of the chassis, if you count the special editions). Despite a considerable list of changes, it was offered at the same price point as the TRF 417 and 417X. This version was based on what driver Jilles Groskamp used to win the IFMAR ISTC world championship earlier in 2012. I present a detailed list of the changes to each major generation of the model below.
TRF 417X Changes
The TRF 417 is extremely similar to the TRF 416. Like all the TRF touring car chassis, this a twin belt driven 4WD model with carbon fiber chassis plates, loads of machined aluminum parts, and generally the best parts Tamiya could come up with including hardware and axles. The general layout with the electronics on one side and the battery on the other is the same. The real changes are all in the details and are explained much further in my build journal below. The TRF 417X comes in a small box with a carrying handle like many standalone chassis. There is no box art on this kind of box, instead there is an insert on the side with the relevant details about the model and a small photograph. Bonus parts included! I wonder what that means. There were an extra set of springs in the box so I guess that's what counts as bonus. When the box is opened you see very little. The box looks almost empty with only a few molded plastic parts visible. Everything else is beneath the divider. Because TRF kits don't come with a body, the sticker sheet doesn't represent any particular livery. These TRF 417X stickers are unique to this model. All of the parts are laid out on my table. I've knolled all the parts, set out the manual, and have prepared to start the build. There is a lot of aluminum and carbon here. It looks like there aren't many parts, but that's because so much hardware is consolidated in the trays. Attachments:
While writing about this build, I am going to concentrate on the differences between this and the last chassis in the TRF line I built (the
TRF 416
The TRF 417 (and the prior TRF models) had a ball differential but the TRF 417X came with these GV parts which are the internal gears for a rear sealed gear differential. The carbon filled Nylon parts were first introduced with the TA-06 earlier in 2011, about the same time as a special edition of the TRF 417 was released with the same option. The plastic cross piece which supports the spider gears was not used for the TRF models; metal shafts were used instead. Here we can see the Delrin housing for the gear differential along with the gears, bearings, shafts, seals, and oil. The kit comes with clear (900 weight) shock oil for filling the differential which is actually pretty thin and offers only minimal resistance to motion. The 37T pulley is built into one side of the housing. On the right I've inserted one of the aluminum drive cups and placed an o-ring over it. This will serve to keep the oil inside the differential where it belongs. There are no bearings supporting the drive cups; they ride directly on the diff housing. A 0.1mm shim is then placed over the seal followed by a 1.6x8mm pin. Inserting the pin is an exercise in frustration because of the very limited access. You'll need a sharp pointed tweezers to manage it. The side gears fit over the pin which lock them to the drive cups. On the right you can see that I've also installed the gasket which should seal the two housings together. The four spider gears are supported by titanium coated cross shafts which are notched to overlap at the center as shown on the left. Optional steel gears are available if you want to make more noise. After this step the volume is filled (mostly) with oil. On the right the two housings have been connected with four tiny 2x8mm countersunk screws and then the large 15x10mm bearings and tensioning cams have been installed. Attachments: |
My personal suspicion is that the primary reason for the TRF 417X was to get rid of the one-piece center bulkhead which had to be machined out of a giant block of aluminum and replace it with a three-piece version that could be much more simply machined out of thin plates. Tamiya says "the previous one-piece motor mount has been replaced with a three-piece type to allow further adjustment of chassis flexibility by linking them together", but that sounds like marketing spin to me. I compare the center bulkheads in the images below, and you can see how difficult it would be to machine the one-piece mount with only the minimal base connecting the vertical sides. The new bulkhead could potentially be installed omitting the center (red) part which would reduce stiffness in the chassis, though the manual makes no specific mention of this option. These images also convey the relief cuts that were added to the lower chassis deck to add flexibility.
Here we can see the parts for the new three-piece center bulkhead as well as the rear bulkheads and suspension mount. Whereas previous models had used unique front and rear bulkheads, for the TRF 417 models front and rear use the same parts. These upper bulkheads are very similar, but not identical, to those from the TRF 416. After the rear differential is installed with the short rear belt, the upper bulkheads capture the bearings as well as providing three mounting hole options for the upper suspension links. These pictures show the belt tensioning cams. The picture on the right shows the little triangular indexing mark which is aligned with the tang on the bulkhead for the default position. The cam can be rotated to move the bearings forward or backward to add or relieve tension on the belt. The whole cam can also be flipped 180 degrees (aligning with a circular mark instead of the triangular mark) to decrease the ride height. Attachments: |
Last edit: by blakbird.
The 105T spur gear from the TRF 416 has been replaced with two options: 111T and 113T (left). Those six large holes around the outer edge are used to access the motor mounting screw. The 15T center pulleys have also been replaced with larger 19T versions (right). These seem to be made from three parts: an aluminum housing and cap, and a bronze toothed pulley. It is not immediately clear how these are connected, but I suspect they are just pressed together. They cannot be disassembled.
The pulleys are connected directly to the spur gear so there is no center one-way bearing in this design. The center shaft assembly then drops into the center bulkhead. One subtle difference from the TRF 416 is that now the short rear belt is on the left side of the spur gear instead of on the right. This leaves slightly less room for the battery but more room for electronics. This may have been done because the TRF 417 was the first Tamiya chassis designed for brushless motors which use larger controllers, and lithium batteries which are much lighter and can be installed further outboard. Now we can install the front bulkheads, front suspension mount, and steering posts. That black steel part with "TRF" written on it doubles as both a 15g ballast weight and a side positioning stop for the battery. All of the TRF chassis had used a front one-way through the TRF 416 until the World Edition. The TRF 417 models all use a front direct coupling which is just a solid shaft that passes through (and locks to) the front pulley and attaches directly to the drive cups. These are plastic drive cups with an aluminum retaining ring over them, presumably to keep them from ballooning at high rpm. I'm not sure this strategy saves anything over just making them from aluminum to start with. I suppose the plastic provides some amount of cushioning when applying sudden power to the front axles. Attachments: |
Here the front pulley has been installed and captured by the upper bulkheads. The front upper bulkheads are the same parts used on the rear. Both belts are now installed and tensioned.
These steering cranks and bridge are very similar to those from the TRF 416. One difference is that there is now no bracket connecting them together and to the upper chassis deck; instead they just float above the lower chassis deck. This supposedly adds more flexibility to the chassis. The upper deck connects the front and rear bulkheads and also captures the bearings for the center shaft. This means the whole upper deck has to be removed to access the center shaft for maintenance. There is also a smaller upper brace that connects the rear bulkheads to the center bulkheads. There is a center belt support built into the upper deck as shown on the right. Tamiya sure does like changing suspension arms. These new arms (front and rear) were introduced with the TB Evolution 5 and have more symmetric bracing compared to the older arms. They are made from carbon filled plastic and are quite rigid. Flipping them allows access to different ball joint positions. Attachments: |
The uprights have not changed, but the CVD axles have. Whereas the TRF 416 axles retained the cross pin with a set screw, the TRF 417 axles use a circular retaining ring with a tang that clips into a hole in the axle. These retaining rings are installed symmetrically on the left and the right so that their direction of spin tends to keep them installed rather than loosen them. The clamping wheel hexes have stayed the same.
As previously discussed, the front arms have also been changed. Here the integral plastic ball joints are being used to connect to the vertical rods for the sway bars. The plastic balls are 4mm (versus 5mm for the aluminum versions), so smaller ball cups (black) need to be used, and the larger cups (gray) at the other end need to be trimmed to fit. Here's a closer look at some interesting parts of the front suspension. Can you spot the difference between those bushings (left)? Probably not because one of them is 4.5x3.5mm and the other is 4.6x4.7mm (both with a 3mm bore). The difference in height may have some explanation, but why the 0.1mm difference in outer diameter? Is it to prevent installing the larger one in the wrong hole? Nope, the hole tolerances are such that it fits anyway. The primary effect is that it is really easy to get them wrong when building the front suspension which uses one for the upper kingpin and the other for the lower. These parts are carried over from the TRF 416. Can you spot the difference between those pins? Probably not because one is 2x9.8mm and the other is 2x10mm. The shorter one is used in the CVD axles and the longer one to drive the wheel hex. The length of the shorter one is presumably dictated by fitting inside the retaining ring. Why not make all four 9.8mm? Probably because no one makes 9.8mm pins so Tamiya has to cut them down from standard 10mm pins. That's my guess anyway. Can you spot the difference between those two shims? Probably not because one is 0.5mm thick and the other is 0.7mm thick. Unless you have a digital caliper (which I don't), it is pretty hard to figure out which is which. The thicker one is a spacer for the steering knuckle, so inadvertently installing the thinner one instead will introduce some vertical play. The thinner one is a spacer for the upper ball joint. The bearings are shown just to highlight the light gray annular rings which identify these as fluorine sealed bearings, the best that Tamiya makes. The hub carriers (F-parts with integrated 4° caster angle) are carried over from the TRF 416 which in turn came from the TA-05 IFS. The steering knuckles (C-parts) are also from the TRF 416. Only the CVD axles have changed by introducing the retaining ring. While the sway bar system appears to be identical to that used on the TRF 416 with a soft rear stabilizer and medium front stabilizer rod, the part numbers are different. Other stiffnesses are possible but not included in the kit. Attachments: |
These photos show the completed front sway bar installation (left), and rear sway bar installation (right). Like all of the other TRF sway bar installations up to this point, I find that they are not very effective due to insufficient support at the pivot axis.
Time to build the shocks which is always one of my favorite parts. These TRF Special Dampers are the same size and use most of the same parts as the TRF 416 dampers, but with very subtle differences. The position of the rod seal and rod support ring have been swapped (same parts, different assembly position). The TRF 417 also uses the HL (High Lubrication) version of the cylinders which have a special coating on them for reduced friction. This is visible as a slight bronze color on the cylinder versus black on the TRF 416. Finally, my copy of the kit included "bonus parts" which appear limited to the extra set of springs shown at upper left. Based on the wire diameter and pitch, these appear to be stiffer than the stock springs and are labelled as being for use on carpeted (high traction) tracks. The carbon shock towers are shown at right. These have more hole positions that those from the TRF 416, but I'm not a fan of overlapping holes since they are very structurally weak. These photos show the completed front (left) and rear (right) suspension assemblies with the shocks installed. This chassis is complete apart from the electronics. The TRF 417 is the first TRF chassis to have been specifically designed for brushless motors and hard case racing batteries. I happened to have an old unused Speed Passion brushless motor which seemed about the right vintage for this chassis so I installed it. A regular silver can brushed motor actually won't fit, although other Tamiya brushed motors (like Super Stock) will. I've also installed a cheap steering servo just to hold the wheels straight. Attachments: |
This side view shows the two ways to bolt the motor to the motor plate. I've used the upper and lower holes which are located diagonally but are partially blocked the the belt and therefore hard to access. The other option is to use the center horizontal holes. If these are used the left hand hole is only accessible by passing your hex tool through one of the large holes in the spur gear.
The lovely steel battery supports double as12g ballast weights. They don't provide any vertical support so glass tape is still needed to secure the battery. The supports are therefore not strictly necessary to use at all, but they do provide extra lateral support. I've also added the body posts, front bumper, and carbon bumper support. This model came with dish wheels but no tires so I've added a set of cheap racing slicks to be consistent with my other TRF chassis models. The completed chassis is shown at the right. Attachments: |
