charger help 13 years 2 months ago #24028
hi guys
stumbled along this charger while surfing the net.......can u kind fellows tell me wot you think?
www.bmmracing.c...-1803.html
it looks good to me just wondered wot your opinions are :)
jtf
charger help 13 years 2 months ago #24043
IMO not having the ability to balance charge Lipo batteries is a serious omission, and the high charge/discharge rates are not that useful, it's also expensive.
I've got on very well with my IMAX B6 charger - 19.39 GBP at Hobbyking (UK warehouse)( link ) or 28.39 GBP for the mains powered version ( link ).
charger help 13 years 2 months ago #24044
Specs look great but there's a lot around these days for less money...
I am also not sure that it comes with a power supply (since it needs 12V).
Edit - simultaneous post with Jonny...
charger help 13 years 2 months ago #24058
i would be mainly using it for nicad and nimh jonny,i havnt got the lipo bug yet buddy :blink:
im sure i will at some point tho.just be a matter of time,and money :)
it would discharge batteries quicker ? 20Amps may be a little overkill though :laugh:
i found the same charger on ebay for £45 edou.
would you be able to run this off a battery charger,which i used to do with my tamiya 15 minuite quick charger? :woohoo: :whistle:
jtf
charger help 13 years 2 months ago #24062
I never discharge with more than half the capacity myself... :whistle:
What charger is that exactly? I think it's needs a proper power supply...
My own LRP Pulsar 3 didn't have one either (or a Lipo balancer for that matter).
charger help 13 years 2 months ago #24066
can i just ask edou,just to get it straight,if u had a 5000mah battery,is that equivalent to 5 amps.....2500 mah battery is 2.5 amps.is this right?
sorry for the newbie questions,im sure there will be more that come this way,lol
cheers
jon
charger help 13 years 2 months ago #24067
www.ebay.co.uk/...2a30264934
sorry it was an acoms with the cigarrete lighter attatchment cut off and two crocodile clips put on :pinch:
i was young and nieve,i wouldnt do it again or if i knew it was safe i would make it safer. :silly:
jtf
charger help 13 years 2 months ago #24077
Not exactly - 5000mAh is the same as 5Ah.
Catching your drift more, I would say yes. ;)
This is the capacity, which basically means you can draw a 5A current from the battery for an hour...
Generally the maximum I charge packs with is the capacity of the battery.
So if it is a 5Ah battery I don't go further than 5A (for an hour).
Meaning I don't really need a charger that can deliver 20A.
Discharge I usually do at half the capacity, in this case 2.5A (should take about two hours if full).
Hope that answers your question.
Don't think the charger would be a good alternative for power supply. :whistle:
But a matching power transformer (220 to 12V) shouldn't break the bank...
charger help 13 years 2 months ago #24110
that answered my question perfecly,thanks edou. :y:
i didnt mean use the charger as a power supply,i meant i connected the old acoms charger to a 12 volt car battery charger :blush:
if i brought this i would buy a good power transformer,can you,or anybody else recommend a good one,with a steady 12 volt supply? :)
jtf :y:
charger help 13 years 2 months ago #24113
Perso, I anytime heard that low charge is better than fast charge for batteries. But I am not enough patient. I learned that you can charge with higher current. For my 1700 nicad, I charge to 3 or 3.5A. I have a wizzard T2M charger with current trimming. For my 6800mah NIMH, I charged Under 8A but it died after 3 charges. Now I am runing with very old nicd and nimh aqs them a friend gave me and I have 20 min during run with my 1700mah nicd with my 12T brushless combo on my dirt. (only when I have the 4 wheeles :laugh: ).
For fast charges I advice you 1.5 to 2X the intensity of your pack maxi.
The better is a delta peak charger. It is easier (for me)
Time to create page: 0.132 seconds
