charger help 13 years 2 months ago #24115
if i brought this i would buy a good power transformer,can you,or anybody else recommend a good one,with a steady 12 volt supply? :)
jtf :y:
try a power supply from an old laptop. most RC charger take 10 to 20v so that could do the trick.
charger help 13 years 2 months ago #24117
PC power recycling. Low current Under 12V or 5V but sure for charging
Last edit: by stingray-63.
charger help 13 years 2 months ago #24119
I think this is the one something like this one's meant for that charger...
But I guess a power supply like this should also suffice if you put the right connections on (I am not an expert though) :
An Imax B6 charger like Jonny recommended in the second post would be a good, complete and much cheaper alternative. ;)
charger help 13 years 2 months ago #24120
i have a hobbyking eco six. best bang for your buck without the bang, it doesn't explode
charger help 13 years 2 months ago #24122
jtf :y:
I would doubt at laptop power supply would be able to supply enough current for a RC charger. Most are only around 60W.
Edit: I was put off the IMAX B6 because of the number of fakes about. Check carefully.
Edit 2: When I was a kid, I used to run my Acoms clockwork quick charger off my dad's car battery charger. Seemed to work OK - well, I never set anything on fire anyway... :P
Last edit: by Martin Bell.
charger help 13 years 2 months ago #24125
i didnt mean use the charger as a power supply,i meant i connected the old acoms charger to a 12 volt car battery charger
i used to do the same thing also martin with the acoms 15 minuite fast carger with my old 1200 mah pack,lol
im sure a lot of people did it as a cheap alternative to a proper power supply
thanks again guys for your useful feedback,il look more into these power supplys
im not even sure its worth the hastle buying this charger,like you said edou i could just get one thats all in for half the £££
thanks all
im in a quandry now :laugh:
jtf :y:
Last edit: by jon_the_fox.
charger help 13 years 2 months ago #24126
If you only want to charge NiCd or NiMH, the Ripmax Propeak is a good choice. Seems to be well-built and comes up used on eBay pretty frequently. I have a Ripmax IP2500 that I paid about £8 for and runs on mains or 12V.
Time to create page: 0.126 seconds
