This is probably an insert delivered with kits that had the new Mk.2 front suspension, but still using the old manuals.
This makes it even more hard to define whether or not a kit was Mk.1 or Mk.2, as it proves you cannot trust the manual included in the kit. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
But it says that the front with the screws, instead of lugs, is the new revised version. And that is contrary to what is the common belief..... |
Ehh, yes, I missed that.... Strange... Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
That is spooky ... and suggests a few possibilities:
1 - it's a wind up 2 - it's a mistake: the translator got it bass-ackwards 3 - things are as we think, but Tamiya found a big box of parts after they'd changed (or someone ordered the wrong type) and rather than recycle them, well they didn't exactly lie to their customers, but they did take the liberty of BSing them a little 4 - everything we know is wrong! Interesting find - but without corroborating evidence I don't think it's enough to reverse received wisdom. |
To me it's either 1 or 2... Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
And I would like to see the image in a larger format...
The image was found on ebay: www.ebay.com /itm/VINTAGE-TAMIYA-ROUGH-RIDER-MK-PLEASE-SEE-REVISION-NOTE-PIC-/181570613300?pt=UK_ToysGames_RadioControlled_JN&hash=item2a4673b034 Maybe the seller could provide a better pic? THIS IS THE ITEM LINK |
Last edit: by larbut. Reason: added link as ebay widged does not work
