Re: LED Lights 14 years 11 months ago #4412
The round dots are leds, the rest is understandable I think
Re: LED Lights 14 years 11 months ago #4413
thanks jonny that looks much clearer now, just a case of wiring it all up and making it look tidy. at least it will make removing the body easy if i wire it all up to one plug for the RX
Re: LED Lights 14 years 11 months ago #4414
C:\fakepath\led diagram 3.bmp
linky no worky mate
Re: LED Lights 14 years 11 months ago #4415
Now working:laugh:
Re: LED Lights 14 years 11 months ago #4416
so i can get away with 1 resistor? that looks easier to solder up and would make the wiring a lot tidier. thanks, just gotta find the right resistors now
Re: LED Lights 14 years 11 months ago #4417
Yep one works fine if you find the right one, resistor that is..
I use one or one resistor to each led wichever I have the right resistors to do it..
Yes a whole lot tidier with one resistor me thinks...
Just not ask pic of the the wires for my lights on my 4x4 Lunchbox, is a nest...lol
The following user(s) Liked this: agemax
Re: LED Lights 14 years 11 months ago #4418
the resistors i got with the led's measure 96.9 ohms on my meter. the colours are black, black,black,silver, i take it these wont work with a one resistor set up then?????
Re: LED Lights 14 years 11 months ago #4419
I don't remember, but you can double the resistors you have now and see what you get. Can't remember if you double or half the value of the resistors by doing so.
If you half the value, twist 5 resistor together and see hat it will be like..
Re: LED Lights 14 years 11 months ago #4420
cheers but rather be safe than sorry, if you recommend 12.5 ohm resistors i will buy some
Re: LED Lights 14 years 11 months ago #4424
Wot Jonny Retro said.... Except, you only really need 1 resistor - put it in line between Rx + & before the point you split the + wires up to the LEDs. From the spec it looks like they haven't got resistors built in, so you'll need at least 1 in the + feed to the LEDs
Time to create page: 0.212 seconds
