"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25007
Working on the helmets - bunging up holes, trimming back, filling, sanding:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25008
Had trouble with the styrene tube I'd used for the rollcage - as usual Poly glue, superglue & Araldite just didn't work, and even Plastic Weld (Dichloromethane) wasn't up to the job of having the interior wiggled into the shell ... in the end I used strips of cotton cloth & epoxy resin as reinforcement - hopefully it'll just look like padding when everything is painted; oil cooler & fuel tank also added:
Added a filler neck to the fuel tank:
... and air horns:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25009
:woohoo: same the horn pipes :whistle:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25088
I don't seem to have taken any photos of applying Milliput, wet smoothing it, or sanding it afterwards ... just a few pics of putting filler on that, and the body parts in primer after that :blush:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25118
Finished all the aerosol work:
VW Alpine White on the body, roof # plate & lower exhaust
Clear on body & roof # plate
Satin black on tonneau, front license plate, top 1/2 of exhaust, window nets (really not convinced by those)
VW Mars Red on the "fire extinguisher" :whistle:
"Chrome" on back 1/2s of lights
"AA Van Yellow" on front 1/2s of lights
The plan now is to concentrate on getting as much spraying in on other projects as possible before the weather turns (several driver figures, Blackfoot, Wild Willys IIRC).
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25119
:cry: When comes the built? It is so realistic. I would like to do a like level model.
I am crazy by your fast and quality work. :y: :y: :y:
Jonny you are an ARTIST :woohoo:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25120
:huh: Do you use a paint cabin?
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25144
I have no painting facilities at all, I spray bits outside.
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25146
Paint for my Wild Willys failed to turn up so I started the detail painting sooner than expected...
Not so much on the interior as lots of layers need doing:
Drivers:
- base colour for driver suits was 2/3 XF-3 Flat Yellow, 1/3 XF-4 Yellow Green,
- highlights 2/3 XF-2 Flat White, 1/3 above yellow mix,
- lowlights 9 drops above yellow + 1 drop XF-68 NATO Brown
- wash = 9 drops above yellow + 1 drop XF-52 Flat Earth + 3 drops water
Dash:
- base colour: 3ml X2 White + 1 drop X-9 Brown
- Radio: XF-69 NATO Black
- details: X-11 Chrome Silver
(still need to make clocks/gauges)
Oil cooler: X10 Gun Metal, X-11 Chrome Silver
Fuel tank: XF-9 Hull Red, XF-69 Rubber Black, XF-16 Flat Aluminum (sic)
Exterior on the other hand is basically done, though I still need to make a shorter front body post & make holes for it:
Door window apertures & tonneau: XF-69 Rubber Black;
Door handles & front license plate back: XF-69 NATO Black;
Front indicators: X-26 Clear Orange;
Sun Visor: XF-56 Metallic Grey, edge with black 0.7mm Kyosho Micron line tape;
Air Horns: X-7 Red + X-11 Chrome Silver (masking was a little tricky):
Left sill (supposed to be where chromed trim has fallen off revealing surface rust & dirt underneath): dry brushed Humbrol Acrylic #113 Rust + XF-69 NATO Black/water wash:
Right sill (chrome still there): Aluminium foil tape:
Rear Lights: XF-16 Flat Aluminum base, 3 coats X-27 Clear Red, Aluminium foil tape:
Exhaust: XF-69 NATO Black, then X-22 Clear:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25149
:woohoo: AMAZING!!!!!!!!
Time to create page: 0.237 seconds
